changing details to my bodyshapes
PostPosted: Tue Mar 25, 2008 4:40 pm
by xtreek
Hello,
I compile mh in kubuntu. Everithyng OK. I can run the program, I can define sex, and primary details. But when I try to change nose, neck, eyes or other things, I can not do. Why?
I use .deb files, 0.9 and 0.9.1, I used windows binary under wine too, and the same results. I can see sense to this, a body shape helps me design quick, but if I cannot change more than basic, what is the point of this program?
Curiously, the 0.9 release does not work too.
Any help is welcome. I use kubuntu 7.10
Thanks.
Re: changing details to my bodyshapes
PostPosted: Tue Mar 25, 2008 8:38 pm
by Manuel
Have you the targets files in \data\targets ??
PostPosted: Wed Mar 26, 2008 4:40 pm
by xtreek
Well I have folders like abdomen, cheek, ears to upper_legs, that contains from 1 or more files with .target as extension.
To compile, I've followed this link: http://www.opendimension.org/blender_en ... source.php
And I have the console history from compilation, if you want to view it.
I have kubuntu 7.10.
Thank you for your time.
PostPosted: Fri Mar 28, 2008 2:21 pm
by Manuel
it seem a path problem...a sort of problem to find the targets on your system. Very strange...
PostPosted: Fri Mar 28, 2008 6:07 pm
by xtreek
So.... what is it supposed I have to do?
Here you have the compilation history:
sul@sul-desktop:~/makehuman$ ls
animorph-0.3 makehuman-0.9.1-rc1a mhgui-0.2
animorph-0.3.tar.gz makehuman-0.9.1-rc1a.tar.gz mhgui-0.2.tar.gz
sul@sul-desktop:~/makehuman$ cd makehuman-0.9.1-rc1a
sul@sul-desktop:~/makehuman/makehuman-0.9.1-rc1a$ ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking how to create a pax tar archive... gnutar
checking whether to enable maintainer-specific portions of Makefiles... no
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking dependency style of gcc... (cached) gcc3
checking how to run the C preprocessor... gcc -E
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for a sed that does not truncate output... /bin/sed
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognize dependent libraries... pass_all
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking how to run the C++ preprocessor... g++ -E
checking the maximum length of command line arguments... 98304
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking for correct ltmain.sh version... yes
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking whether to enable debugging... no
checking for X... libraries , headers
checking for the pthreads library -lpthreads... no
checking whether pthreads work without any flags... no
checking whether pthreads work with -Kthread... no
checking whether pthreads work with -kthread... no
checking for the pthreads library -llthread... no
checking whether pthreads work with -pthread... no
checking whether pthreads work with -pthreads... no
checking whether pthreads work with -mthreads... no
checking for the pthreads library -lpthread... no
checking whether pthreads work with --thread-safe... no
checking whether pthreads work with -mt... no
checking for pthread-config... no
checking whether we are using the Microsoft C compiler... no
checking windows.h usability... no
checking windows.h presence... no
checking for windows.h... no
checking for OpenGL library... -lGL
checking for OpenGL Utility library... -lGLU
checking for gethostbyname... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking for FreeGLUT library... no
checking for GLUT library... -lglut
checking for windres... no
checking for find... yes
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for PACKAGE... yes
checking for windows.h... (cached) no
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating data/Makefile
config.status: creating pixmaps/Makefile
config.status: creating makehuman.nsi
config.status: creating config.h
config.status: executing depfiles commands
sul@sul-desktop:~/makehuman/makehuman-0.9.1-rc1a$ make
make all-recursive
make[1]: se ingresa al directorio `/home/sul/makehuman/makehuman-0.9.1-rc1a'
Making all in src
make[2]: se ingresa al directorio `/home/sul/makehuman/makehuman-0.9.1-rc1a/src'
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT Animation.o -MD -MP -MF .deps/Animation.Tpo -c -o Animation.o Animation.cpp
mv -f .deps/Animation.Tpo .deps/Animation.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT BodyPanel.o -MD -MP -MF .deps/BodyPanel.Tpo -c -o BodyPanel.o BodyPanel.cpp
mv -f .deps/BodyPanel.Tpo .deps/BodyPanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT FacePanel.o -MD -MP -MF .deps/FacePanel.Tpo -c -o FacePanel.o FacePanel.cpp
mv -f .deps/FacePanel.Tpo .deps/FacePanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT TeethPanel.o -MD -MP -MF .deps/TeethPanel.Tpo -c -o TeethPanel.o TeethPanel.cpp
mv -f .deps/TeethPanel.Tpo .deps/TeethPanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT HandsPanel.o -MD -MP -MF .deps/HandsPanel.Tpo -c -o HandsPanel.o HandsPanel.cpp
mv -f .deps/HandsPanel.Tpo .deps/HandsPanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT FooterPanel.o -MD -MP -MF .deps/FooterPanel.Tpo -c -o FooterPanel.o FooterPanel.cpp
mv -f .deps/FooterPanel.Tpo .deps/FooterPanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT ViewPanel.o -MD -MP -MF .deps/ViewPanel.Tpo -c -o ViewPanel.o ViewPanel.cpp
mv -f .deps/ViewPanel.Tpo .deps/ViewPanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT TooltipPanel.o -MD -MP -MF .deps/TooltipPanel.Tpo -c -o TooltipPanel.o TooltipPanel.cpp
mv -f .deps/TooltipPanel.Tpo .deps/TooltipPanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT ImageListener.o -MD -MP -MF .deps/ImageListener.Tpo -c -o ImageListener.o ImageListener.cpp
ImageListener.cpp: In member function ‘virtual bool ImageListener::mouseReleased(const mhgui::Point&, int, mhgui::Component*)’:
ImageListener.cpp:133: aviso: variable ‘bs_p’ sin usar
ImageListener.cpp:134: aviso: variable ‘pb_p’ sin usar
mv -f .deps/ImageListener.Tpo .deps/ImageListener.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT makehuman.o -MD -MP -MF .deps/makehuman.Tpo -c -o makehuman.o makehuman.cpp
makehuman.cpp:767: aviso: se definió ‘void renderMeshEdges()’ pero no se usa
makehuman.cpp:458: aviso: se definió ‘void closeWindow()’ pero no se usa
mv -f .deps/makehuman.Tpo .deps/makehuman.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT UtilitybarPanel.o -MD -MP -MF .deps/UtilitybarPanel.Tpo -c -o UtilitybarPanel.o UtilitybarPanel.cpp
mv -f .deps/UtilitybarPanel.Tpo .deps/UtilitybarPanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT ConsoleListener.o -MD -MP -MF .deps/ConsoleListener.Tpo -c -o ConsoleListener.o ConsoleListener.cpp
mv -f .deps/ConsoleListener.Tpo .deps/ConsoleListener.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT Global.o -MD -MP -MF .deps/Global.Tpo -c -o Global.o Global.cpp
mv -f .deps/Global.Tpo .deps/Global.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT TargetSliderListener.o -MD -MP -MF .deps/TargetSliderListener.Tpo -c -o TargetSliderListener.o TargetSliderListener.cpp
mv -f .deps/TargetSliderListener.Tpo .deps/TargetSliderListener.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT TargetSelectionListener.o -MD -MP -MF .deps/TargetSelectionListener.Tpo -c -o TargetSelectionListener.o TargetSelectionListener.cpp
mv -f .deps/TargetSelectionListener.Tpo .deps/TargetSelectionListener.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT ToolbarPanel.o -MD -MP -MF .deps/ToolbarPanel.Tpo -c -o ToolbarPanel.o ToolbarPanel.cpp
mv -f .deps/ToolbarPanel.Tpo .deps/ToolbarPanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT TargetPanel.o -MD -MP -MF .deps/TargetPanel.Tpo -c -o TargetPanel.o TargetPanel.cpp
mv -f .deps/TargetPanel.Tpo .deps/TargetPanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT util.o -MD -MP -MF .deps/util.Tpo -c -o util.o util.cpp
util.cpp: In function ‘bool loadSelectorsPositions(const std::string&)’:
util.cpp:2218: aviso: variable ‘tmp’ sin usar
util.cpp:2219: aviso: variable ‘tmp1’ sin usar
util.cpp: In function ‘bool loadSelectorsPositions(const std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >&, float)’:
util.cpp:2243: aviso: variable ‘buffer’ sin usar
util.cpp:2244: aviso: variable ‘tmp’ sin usar
util.cpp:2245: aviso: variable ‘tmp1’ sin usar
mv -f .deps/util.Tpo .deps/util.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT BottomPanel.o -MD -MP -MF .deps/BottomPanel.Tpo -c -o BottomPanel.o BottomPanel.cpp
mv -f .deps/BottomPanel.Tpo .deps/BottomPanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT PoseTargetPanel.o -MD -MP -MF .deps/PoseTargetPanel.Tpo -c -o PoseTargetPanel.o PoseTargetPanel.cpp
mv -f .deps/PoseTargetPanel.Tpo .deps/PoseTargetPanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT PoseTargetSelectionListener.o -MD -MP -MF .deps/PoseTargetSelectionListener.Tpo -c -o PoseTargetSelectionListener.o PoseTargetSelectionListener.cpp
mv -f .deps/PoseTargetSelectionListener.Tpo .deps/PoseTargetSelectionListener.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT PosesBodyPanel.o -MD -MP -MF .deps/PosesBodyPanel.Tpo -c -o PosesBodyPanel.o PosesBodyPanel.cpp
mv -f .deps/PosesBodyPanel.Tpo .deps/PosesBodyPanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT PoseTargetSliderListener.o -MD -MP -MF .deps/PoseTargetSliderListener.Tpo -c -o PoseTargetSliderListener.o PoseTargetSliderListener.cpp
mv -f .deps/PoseTargetSliderListener.Tpo .deps/PoseTargetSliderListener.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT BsPanel.o -MD -MP -MF .deps/BsPanel.Tpo -c -o BsPanel.o BsPanel.cpp
mv -f .deps/BsPanel.Tpo .deps/BsPanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT BsSelectionListener.o -MD -MP -MF .deps/BsSelectionListener.Tpo -c -o BsSelectionListener.o BsSelectionListener.cpp
mv -f .deps/BsSelectionListener.Tpo .deps/BsSelectionListener.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT CharacterSettingPanel.o -MD -MP -MF .deps/CharacterSettingPanel.Tpo -c -o CharacterSettingPanel.o CharacterSettingPanel.cpp
mv -f .deps/CharacterSettingPanel.Tpo .deps/CharacterSettingPanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT ClothesPanel.o -MD -MP -MF .deps/ClothesPanel.Tpo -c -o ClothesPanel.o ClothesPanel.cpp
mv -f .deps/ClothesPanel.Tpo .deps/ClothesPanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT PageTargetPanel.o -MD -MP -MF .deps/PageTargetPanel.Tpo -c -o PageTargetPanel.o PageTargetPanel.cpp
mv -f .deps/PageTargetPanel.Tpo .deps/PageTargetPanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT FileTools.o -MD -MP -MF .deps/FileTools.Tpo -c -o FileTools.o FileTools.cpp
mv -f .deps/FileTools.Tpo .deps/FileTools.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT SplashPanel.o -MD -MP -MF .deps/SplashPanel.Tpo -c -o SplashPanel.o SplashPanel.cpp
mv -f .deps/SplashPanel.Tpo .deps/SplashPanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT UtilitiesPanel.o -MD -MP -MF .deps/UtilitiesPanel.Tpo -c -o UtilitiesPanel.o UtilitiesPanel.cpp
mv -f .deps/UtilitiesPanel.Tpo .deps/UtilitiesPanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT UtilitiesSliderListener.o -MD -MP -MF .deps/UtilitiesSliderListener.Tpo -c -o UtilitiesSliderListener.o UtilitiesSliderListener.cpp
mv -f .deps/UtilitiesSliderListener.Tpo .deps/UtilitiesSliderListener.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT SelectorListener.o -MD -MP -MF .deps/SelectorListener.Tpo -c -o SelectorListener.o SelectorListener.cpp
mv -f .deps/SelectorListener.Tpo .deps/SelectorListener.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT BsCategoryPanel.o -MD -MP -MF .deps/BsCategoryPanel.Tpo -c -o BsCategoryPanel.o BsCategoryPanel.cpp
mv -f .deps/BsCategoryPanel.Tpo .deps/BsCategoryPanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT PosesBsCategoryPanel.o -MD -MP -MF .deps/PosesBsCategoryPanel.Tpo -c -o PosesBsCategoryPanel.o PosesBsCategoryPanel.cpp
mv -f .deps/PosesBsCategoryPanel.Tpo .deps/PosesBsCategoryPanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT PosesBsSelectionListener.o -MD -MP -MF .deps/PosesBsSelectionListener.Tpo -c -o PosesBsSelectionListener.o PosesBsSelectionListener.cpp
mv -f .deps/PosesBsSelectionListener.Tpo .deps/PosesBsSelectionListener.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT PagePosesBsPanel.o -MD -MP -MF .deps/PagePosesBsPanel.Tpo -c -o PagePosesBsPanel.o PagePosesBsPanel.cpp
mv -f .deps/PagePosesBsPanel.Tpo .deps/PagePosesBsPanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT PosesBsPanel.o -MD -MP -MF .deps/PosesBsPanel.Tpo -c -o PosesBsPanel.o PosesBsPanel.cpp
mv -f .deps/PosesBsPanel.Tpo .deps/PosesBsPanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT PageBsPanel.o -MD -MP -MF .deps/PageBsPanel.Tpo -c -o PageBsPanel.o PageBsPanel.cpp
mv -f .deps/PageBsPanel.Tpo .deps/PageBsPanel.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT PosesBsPanelSelectionListener.o -MD -MP -MF .deps/PosesBsPanelSelectionListener.Tpo -c -o PosesBsPanelSelectionListener.o PosesBsPanelSelectionListener.cpp
mv -f .deps/PosesBsPanelSelectionListener.Tpo .deps/PosesBsPanelSelectionListener.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -Wall -g -O2 -MT BsPanelSelectionListener.o -MD -MP -MF .deps/BsPanelSelectionListener.Tpo -c -o BsPanelSelectionListener.o BsPanelSelectionListener.cpp
mv -f .deps/BsPanelSelectionListener.Tpo .deps/BsPanelSelectionListener.Po
/bin/bash ../libtool --tag=CXX --mode=link g++ -I/usr/local/include -Wall -g -O2 -o makehuman Animation.o BodyPanel.o FacePanel.o TeethPanel.o HandsPanel.o FooterPanel.o ViewPanel.o TooltipPanel.o ImageListener.o makehuman.o UtilitybarPanel.o ConsoleListener.o Global.o TargetSliderListener.o TargetSelectionListener.o ToolbarPanel.o TargetPanel.o util.o BottomPanel.o PoseTargetPanel.o PoseTargetSelectionListener.o PosesBodyPanel.o PoseTargetSliderListener.o BsPanel.o BsSelectionListener.o CharacterSettingPanel.o ClothesPanel.o PageTargetPanel.o FileTools.o SplashPanel.o UtilitiesPanel.o UtilitiesSliderListener.o SelectorListener.o BsCategoryPanel.o PosesBsCategoryPanel.o PosesBsSelectionListener.o PagePosesBsPanel.o PosesBsPanel.o PageBsPanel.o PosesBsPanelSelectionListener.o BsPanelSelectionListener.o -L/usr/local/lib -lanimorph -lmhgui -lglut -lSM -lICE -lXmu -lXi -lGLU -lGL -lm
mkdir .libs
g++ -I/usr/local/include -Wall -g -O2 -o makehuman Animation.o BodyPanel.o FacePanel.o TeethPanel.o HandsPanel.o FooterPanel.o ViewPanel.o TooltipPanel.o ImageListener.o makehuman.o UtilitybarPanel.o ConsoleListener.o Global.o TargetSliderListener.o TargetSelectionListener.o ToolbarPanel.o TargetPanel.o util.o BottomPanel.o PoseTargetPanel.o PoseTargetSelectionListener.o PosesBodyPanel.o PoseTargetSliderListener.o BsPanel.o BsSelectionListener.o CharacterSettingPanel.o ClothesPanel.o PageTargetPanel.o FileTools.o SplashPanel.o UtilitiesPanel.o UtilitiesSliderListener.o SelectorListener.o BsCategoryPanel.o PosesBsCategoryPanel.o PosesBsSelectionListener.o PagePosesBsPanel.o PosesBsPanel.o PageBsPanel.o PosesBsPanelSelectionListener.o BsPanelSelectionListener.o -L/usr/local/lib /usr/local/lib/libmhgui.so /usr/local/lib/libanimorph.so -lpng -lglut -lSM -lICE -lXmu -lXi -lGLU -lGL -lm
make[2]: se sale del directorio `/home/sul/makehuman/makehuman-0.9.1-rc1a/src'
Making all in data
make[2]: se ingresa al directorio `/home/sul/makehuman/makehuman-0.9.1-rc1a/data'
make[2]: No se hace nada para `all'.
make[2]: se sale del directorio `/home/sul/makehuman/makehuman-0.9.1-rc1a/data'
Making all in pixmaps
make[2]: se ingresa al directorio `/home/sul/makehuman/makehuman-0.9.1-rc1a/pixmaps'
make[2]: se sale del directorio `/home/sul/makehuman/makehuman-0.9.1-rc1a/pixmaps'
make[2]: se ingresa al directorio `/home/sul/makehuman/makehuman-0.9.1-rc1a'
make[2]: No se hace nada para `all-am'.
make[2]: se sale del directorio `/home/sul/makehuman/makehuman-0.9.1-rc1a'
make[1]: se sale del directorio `/home/sul/makehuman/makehuman-0.9.1-rc1a'
sul@sul-desktop:~/makehuman/makehuman-0.9.1-rc1a$ sudo make install
Making install in src
make[1]: se ingresa al directorio `/home/sul/makehuman/makehuman-0.9.1-rc1a/src'
test -z "/usr/local/bin" || /bin/mkdir -p "/usr/local/bin"
/bin/bash ../libtool --mode=install /usr/bin/install -c 'makehuman' '/usr/local/bin/makehuman'
/usr/bin/install -c makehuman /usr/local/bin/makehuman
make[2]: No se hace nada para `install-data-am'.
make[1]: se sale del directorio `/home/sul/makehuman/makehuman-0.9.1-rc1a/src'
Making install in data
make[1]: se ingresa al directorio `/home/sul/makehuman/makehuman-0.9.1-rc1a/data'
make[2]: No se hace nada para `install-exec-am'.
/bin/bash /home/sul/makehuman/makehuman-0.9.1-rc1a/install-sh -d /usr/local/share/makehuman
find . -name '*.bs' -exec cp --parents {} /usr/local/share/makehuman \;
find /usr/local/share/makehuman -name '*.bs' -exec chmod 0644 {} \;
find . -name '*.target' -exec cp --parents {} /usr/local/share/makehuman \;
find /usr/local/share/makehuman -name '*.target' -exec chmod 0644 {} \;
find . -name '*.template' -exec cp --parents {} /usr/local/share/makehuman \;
find /usr/local/share/makehuman -name '*.template' -exec chmod 0644 {} \;
find . -name '*.sl' -exec cp --parents {} /usr/local/share/makehuman \;
find /usr/local/share/makehuman -name '*.sl' -exec chmod 0644 {} \;
find . -name '*.tif' -exec cp --parents {} /usr/local/share/makehuman \;
find /usr/local/share/makehuman -name '*.tif' -exec chmod 0644 {} \;
find . -name '*.rot' -exec cp --parents {} /usr/local/share/makehuman \;
find /usr/local/share/makehuman -name '*.rot' -exec chmod 0644 {} \;
find . -name '*.info' -exec cp --parents {} /usr/local/share/makehuman \;
find /usr/local/share/makehuman -name '*.info' -exec chmod 0644 {} \;
find . -name '*.camera' -exec cp --parents {} /usr/local/share/makehuman \;
find /usr/local/share/makehuman -name '*.camera' -exec chmod 0644 {} \;
test -z "/usr/local/share/makehuman" || /bin/mkdir -p "/usr/local/share/makehuman"
/usr/bin/install -c -m 644 'base.body' '/usr/local/share/makehuman/base.body'
/usr/bin/install -c -m 644 'base.faces' '/usr/local/share/makehuman/base.faces'
/usr/bin/install -c -m 644 'base.skin' '/usr/local/share/makehuman/base.skin'
/usr/bin/install -c -m 644 'base.subde' '/usr/local/share/makehuman/base.subde'
/usr/bin/install -c -m 644 'base.uv' '/usr/local/share/makehuman/base.uv'
/usr/bin/install -c -m 644 'default.bs' '/usr/local/share/makehuman/default.bs'
/usr/bin/install -c -m 644 'base.clothes' '/usr/local/share/makehuman/base.clothes'
/usr/bin/install -c -m 644 'base.materials' '/usr/local/share/makehuman/base.materials'
/usr/bin/install -c -m 644 'base.smooth' '/usr/local/share/makehuman/base.smooth'
/usr/bin/install -c -m 644 'base.subdf' '/usr/local/share/makehuman/base.subdf'
/usr/bin/install -c -m 644 'base.vertices' '/usr/local/share/makehuman/base.vertices'
/usr/bin/install -c -m 644 'base.colors' '/usr/local/share/makehuman/base.colors'
/usr/bin/install -c -m 644 'base.parts' '/usr/local/share/makehuman/base.parts'
/usr/bin/install -c -m 644 'base.strips' '/usr/local/share/makehuman/base.strips'
/usr/bin/install -c -m 644 'base.subdo' '/usr/local/share/makehuman/base.subdo'
/usr/bin/install -c -m 644 'subd.parts' '/usr/local/share/makehuman/subd.parts'
make[1]: se sale del directorio `/home/sul/makehuman/makehuman-0.9.1-rc1a/data'
Making install in pixmaps
make[1]: se ingresa al directorio `/home/sul/makehuman/makehuman-0.9.1-rc1a/pixmaps'
/bin/bash /home/sul/makehuman/makehuman-0.9.1-rc1a/install-sh -d /usr/local/share/pixmaps/makehuman
find . -name '*.png' -exec cp --parents {} /usr/local/share/pixmaps/makehuman \;
find /usr/local/share/pixmaps/makehuman -name '*.png' -exec chmod 0644 {} \;
test -z "/usr/local/share/pixmaps/makehuman" || /bin/mkdir -p "/usr/local/share/pixmaps/makehuman"
make[1]: se sale del directorio `/home/sul/makehuman/makehuman-0.9.1-rc1a/pixmaps'
test -z "/usr/local/doc/makehuman" || /bin/mkdir -p "/usr/local/doc/makehuman"
/usr/bin/install -c -m 644 'README.txt' '/usr/local/doc/makehuman/README.txt'
/usr/bin/install -c -m 644 'COPYING' '/usr/local/doc/makehuman/COPYING'
/usr/bin/install -c -m 644 'COPYING.MIT' '/usr/local/doc/makehuman/COPYING.MIT'
/usr/bin/install -c -m 644 'AUTHORS' '/usr/local/doc/makehuman/AUTHORS'
/usr/bin/install -c -m 644 'ChangeLog' '/usr/local/doc/makehuman/ChangeLog'
/usr/bin/install -c -m 644 'INSTALL' '/usr/local/doc/makehuman/INSTALL'
/usr/bin/install -c -m 644 'NEWS' '/usr/local/doc/makehuman/NEWS'
/usr/bin/install -c -m 644 'TODO' '/usr/local/doc/makehuman/TODO'
sul@sul-desktop:~/makehuman/makehuman-0.9.1-rc1a$ sudo ldconfig
sul@sul-desktop:~/makehuman/makehuman-0.9.1-rc1a$ makehuman
With last command, I run the program. Sorry, only 60000 characters admitted. The mkgui and animorph compilation left not included.
