Missing MPFB2 in Blender 4.2
Re: Missing MPFB2 in Blender 4.2
Postby bojanakovacic » Fri Aug 16, 2024 8:05 am
Ensure each pose has its own folder with the BVH file and a metadata file in the correct format. Create a '.pose' metadata file with the required information and place it in the same folder as the BVH file. After organizing your files, refresh the pose library in Blender or restart the program.
bojanakovacic
Postby theyonatan » Sat Mar 08, 2025 12:55 pm
sorry to necropost, I am also experiencing this bug.
an image of my assets folder attached.
I tried restarting, adding from zip but nothing seems to work. the assets won't appear in Blender where they are expected.
I get the notification log that they should appear after restart.
is there any log I can find and share for this? thanks
theyonatan
Postby tomcat » Sat Mar 08, 2025 9:45 pm
theyonatan wrote:an image of my assets folder attached.
That's not the way the assets will appear.
You need to create folders: “clothes”, “hair” etc. And in them, respectively, put clothes, hairstyles and so on.
Postby joepal » Sun Mar 09, 2025 8:39 am
Whar tomcat says. This looks as if yuo unzipped the assets manually in the data directory.
Also, check if you have two instances of MPFB in the extensions/addons lists under preferences. In that case the wrong dir might be found.
