Import data from matlab
Postby newby » Fri Dec 16, 2022 4:06 pm
I'm writing because I didn't find a question related to import data from Matlab.
I need to import data saved in a .mat file from Matlab.
In Blender i could do the same thing with:
import scipy.io
from scipy.io import loadmat
mat = loadmat(' filepath')
Here I have trouble that MH recognizes the scipy package. Errormessage --> ModuleNotFoundError: No module named 'scipy'
So my question would be, where have the folders from https://github.com/scipy/scipy/tree/main/scipy have to be that MH recognizes it and is able to import it?
newby
Re: Import data from matlab
Postby Aranuvir » Fri Dec 16, 2022 7:22 pm
Interesting. I didn't know, scipy is a dependency of Blender and not so surprisingly the import statement gave the same ModuleNotFoundError...
However, back to MakeHuman.
I don't know why, but I get the impression you are working on Windows, otherwise your solution should be straight forward. On Windows the MakeHuman package is distributed with its own Python interpreter, that's why it can't find other dependencies. Your best solution would be running MakeHuman from source. The amount of dependencies is minimal (PyQt5, numpy and pyopengl). And if you want some Ipython support in MakeHuman's shell, get jupyterlab/qtconsole.
Good luck!
Postby joepal » Sat Dec 17, 2022 10:47 am
EDIT: Sorry, I misunderstood the question
Theoretically you can use PIP to update the bundled python dependencies, even with the minimal python that MH ships with. I have not tested this, but if you find the python executable in a cmd window, you should be able to do:
python.exe -m ensurepip
python.exe -m pip install --upgrade pip
python.exe -m pip install --upgrade scipy
For this to work you need to have write access to where you installed MH.
However, as Aranuvir says, you're probably better off running makehuman from source. Download a proper python installation, use PIP to install scipy and the dependencies needed by MH and then run the makehuman.py script directly. There are more detailed instructions at https://github.com/makehumancommunity/m ... /README.md
Postby newby » Tue Dec 20, 2022 9:55 am
Thanks for your help.
In the end I converted my mat files to json files, this way it was possible to avoid scipy.
newby
