Problem modifying targets via script
Postby ortho12 » Mon Nov 14, 2022 7:43 am
Hi everyone,
I am trying to create an avatar from biplanar X-ray images. To automate the model creation, I have calculated different distances and circumferences from the image and now I want to apply them to the MH model without using the GUI sliders.
I found this script https://github.com/RtjShreyD/Playing-wi ... ifiers2.py which allows to modify the targets from 0 to 1. The problem is that the range of the targets of the statistical model keeps changing when the other targets are changed. I also found the base mesh for each target, but that alone is not enough, as it only scales something.
So my question would be: Is the statistical reference model defined somewhere? Or is it possible to directly insert the metric values directly into the script, as this would be much easier?
I would be grateful for any help.
P.S.: Example of the basemesh of a target: https://github.com/makehumancommunity/m ... ecr.target
ortho12
Re: Problem modifying targets via script
Postby joepal » Tue Nov 15, 2022 6:21 am
Yes, this is a frequent discussion. The basic summary is: it's not that easy.
First, there is no "statistical" model in the sense that it'd be based on a stochastic distribution of values. There is a 3d model which has been hand designed to look the way an artist thinks a human looks. That baseline is "base.obj" here: https://github.com/makehumancommunity/m ... ata/3dobjs
Second, all transforms are completely deterministic. If you have a target that moves the vertex on the nose tip 0.1 along the Y axis, then it will always do exactly that. When that target is applied at 100% the vertex will be shifted 0.1 compared to a state where it is not applied. At 50% it will be shifted 0.05. This, and exactly this, will always happen, independently on which other targets have already been applied.
The last part is important, and herein lies the problem for you. A target only cares about its own transforms and does not take into account which other transforms have already been made.
This is what makes "metric" values very, very tricky. Sure, you can make a target that expands the waist circumference with 20 centimeter on a baseline model by moving each relevant vertex around the waist a few units of distance along the XY plane. However, if a model has already had another target applied, such as the weight macro target or pregnant belly or something, then that is the baseline instead. The vertices will still shift exactly in the manner you specified, but the end result will probably be different than when you designed the target.
So, that's describing the problem. Is there a solution?
I think you're toast if you try to design a system that both needs to be completely predictable and take arbitrary targets into account for your baseline. Maybe you could limit the scope to one or a few exact baseline(s) instead and work from there? Maybe one male and one female? If you know what the baseline is, then a comparison between that baseline and your xray images should be reasonably easy to convert into targets.
