will not open
will not open
Postby Jebb21 » Fri Oct 14, 2022 8:35 pm
installed but will not open
running windows 11
AMD Ryzen 5 4600H Radeon graphics 3001Mhz 6 cores 12 Logical processors
Jebb21
Re: will not open
Postby tomcat » Fri Oct 14, 2022 9:47 pm
Jebb21 wrote:installed but will not open
How are you trying to run the program?
Here are similar topics:
viewtopic.php?f=6&t=20605
viewtopic.php?f=3&t=19748
Re: will not open
Postby Jebb21 » Sat Oct 15, 2022 9:50 am
tried running
discovered a erro report for Python
Initialized logging
VERSION: 1.2.0 final
SHORT VERSION: final
LONG VERSION: 1.2.0 final (HEAD:c28443c2)
BASEMESH VERSION: hm08
IS BUILT (FROZEN): No
IS RELEASE VERSION: Yes
DEFAULT ENCODING: utf-8
FILESYSTEM ENCODING: utf-8
STDOUT ENCODING: cp1252
LOCALE PREFERRED ENCODING: cp1252
WORKING DIRECTORY: C:\Program Files\makehuman-community\makehuman
HOME LOCATION: C:/Users/jebbs/OneDrive/Documents
PYTHON PATH: ./;./lib;./apps;./shared;./apps/gui;./core;C:\Program Files\makehuman-community\Python\python37.zip;C:\Program Files\makehuman-community\Python;C:\Program Files\makehuman-community\pkgs
DLL PATH: C:\Program Files\makehuman-community\pkgs\PyQt5\Qt\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Users\jebbs\AppData\Local\Microsoft\WindowsApps;
SYS.VERSION: 3.7.6 (tags/v3.7.6:43364a7ae0, Dec 19 2019, 00:42:30) [MSC v.1916 64 bit (AMD64)]
SYS.PLATFORM: win32
SYS.EXECUTABLE: C:\Program Files\makehuman-community\Python\pythonw.exe
PLATFORM.MACHINE: AMD64
PLATFORM.PROCESSOR: AMD64 Family 23 Model 96 Stepping 1, AuthenticAMD
PLATFORM.UNAME.RELEASE: 10
PLATFORM.WIN32_VER: 10 10.0.22621 SP0
NUMPY.VERSION: 1.18.1
No OpenGL_accelerate module loaded: No module named 'OpenGL_accelerate'
QT.VERSION: 5.12.7
QT.JPG_SUPPORT: supported
QT.SVG_SUPPORT: supported
QT.PLUGIN_PATH: C:/Program Files/makehuman-community/pkgs/PyQt5/Qt/plugins;C:/Program Files/makehuman-community/Python
QT.PLUGIN_PATH_ENV:
QT.CONF: NOT PRESENT
PYOPENGL.VERSION: 3.1.0
NOSHADERS: not set
NOSAMPLEBUFFERS: not set
Failed to write GL debug info to debug dump: GLError(
err = 1282,
description = b'invalid operation',
baseOperation = glGetString,
cArguments = (GL_VENDOR,)
err = 1282,
baseOperation = glGetIntegerv,
pyArgs = (
GL_SAMPLES_ARB,
<object object at 0x000001BD1B36FEB0>,
cArgs = (
GL_SAMPLES_ARB,
array([0], dtype=int32),
cArguments = (
GL_SAMPLES_ARB,
dont know what that means
Jebb21
Re: will not open
Postby tomcat » Sat Oct 15, 2022 10:53 am
Jebb21 wrote:tried running
It is not clear exactly which file you are trying to run.
It looks like you have OneDrive. MH seems to have had problems with it.
Re: will not open
Postby Aranuvir » Sun Oct 16, 2022 7:47 am
Re: will not open
Postby kfkf » Tue Oct 18, 2022 6:50 pm
I have the same problem, and am not using onedrive. I suspect it may be something to do with OpenGL, since Blender gave me an error saying "A graphics card and driver with support for OpenGL 3.3 or higher is required. Installing the latest driver for your graphics card might resolve the issue." the first time I opened it. I got Blender to work by putting .dll file I found online that implements OpenGL in software into the same directory as the .exe file, but the same did not seem to work for Makehuman. Maybe I will try it again.
kfkf
Re: will not open
I have the same problem and error message, and am not using onedrive. I suspect it may be something to do with OpenGL, because of the line reading "[2022-10-18 14:52:54,673] acceleratesupport.py-><module>():17 -- MESSAGE -- No OpenGL_accelerate module loaded: No module named 'OpenGL_accelerate'"
Also, Blender gave me an error saying "A graphics card and driver with support for OpenGL 3.3 or higher is required. Installing the latest driver for your graphics card might resolve the issue." the first time I opened it. I got Blender to work by putting .dll file I found online that implements OpenGL in software into the same directory as the .exe file, but the same did not seem to work for Makehuman. Maybe I will try it again.
EDIT: I tried it again, and it didn't work.
kfkf
Re: will not open
Postby joepal » Thu Oct 20, 2022 3:09 pm
I'd say it is rather random if MH will open at all if even blender complains about the OpenGL implementation.
