Hello :)
Hello :)
Postby BadSad » Sat Apr 30, 2022 7:35 pm
Hello :)
I'm new here :). I've few questions.
1. Is it Possible to turn off download confrimation window. That one that shows up after download is completed?
2. Is it possible to switch camera to perspective from ortographic (and back)?
3. Im working on NSFW Visual Novel and I need to have control on possibly everything, so what do I need to do to import my character from MakeHuman to Blender with rigged face and convert it to rigify ? I tried few things but no luck. Only basic rigify rig without face.
BTW. I would like to introduce to Renee in her early years ;P
Thanks in advance :)
BadSad
Re: Hello :)
Postby joepal » Sun May 01, 2022 2:53 pm
For 1, you'd need to edit the source code of the downloader plugin. Basically comment out llines 327 and 328 in this file: https://github.com/makehumancommunity/m ... ownload.py
For 2, there is an addon for this: https://github.com/black-punkduck/MakeH ... ive-Viewer
For 3, I think you'll have a hard time importing the character rigged and converting to rigify if you also want facial expressions. In this case you'd be better of by using MPFB2 directly, with a rigify meta rig, and then generate when you've finished designing the character. Information about MPFB2 can be found here: http://static.makehumancommunity.org/mpfb.html. This said, the rigify functionality isn't perfect this way either, for example in respects to weight painting. But you'll get full rig including the face.
Re: Hello :)
Postby BadSad » Sun May 01, 2022 3:52 pm
Thank You for reply :)
I guess I'll try to rig MakeHuman character with rigify by hand then :).
BadSad
Re: Hello :)
Postby RubenWarren » Wed Jun 29, 2022 2:47 pm
Hi BadSad, i'm newbie too :D
trap the cat
RubenWarren
Re: Hello :)
Postby leque123 » Fri Aug 12, 2022 2:48 am
BadSad wrote:Hello :)
I'm new here :). I've few questions. subway surfers
2. Is it possible to switch camera to perspective from ortographic (and back)? quordle
thank you, I'm also new and starting to learn about MakeHuman
leque123
