Then you should be able to use the internal asset downloader on the "Community" tab there is a bit of prep that is needed:
1. click the "Community" tab you see two sub-tabs Download assets and socket
2.Check the Socket sub-tab Accept connections is checked (x in the little box)
3. Back to the Download assets sub-tab at the bottom right side click the Synchronize button (wait awhile for it to finish)
4.Now on the left side are a series filters to help you find what you want set the filters to what you searching for and click the "Update
list" button at the bottom of the filters
5.Now the middle window should have all of the assets that match the filter settings click on the one you want then click the
"Download" button in the right pane
Now back to the "Geometries" tab you new asset should now be available for you to use with all the textures too.If you have problems just post again
Enjoy the Choice
