Make human will not launch on win 10
Postby chunkypuding » Sun May 31, 2020 3:51 pm
Hello
I wanted to try using make human on win10 but the software will not launch.
After attempting to launch it, it does nothing, and I mean nothing not even any activity in app manager.
LOG
[2020-05-31 17:36:13,748] log.py->message():118 -- MESSAGE -- Initialized logging
[2020-05-31 17:36:13,754] log.py->debug():97 -- DEBUG -- VERSION: HEAD:748a570b
[2020-05-31 17:36:13,754] log.py->debug():97 -- DEBUG -- SHORT VERSION: beta1
[2020-05-31 17:36:13,754] log.py->debug():97 -- DEBUG -- LONG VERSION: 1.2.0 Beta1 (HEAD:748a570b)
[2020-05-31 17:36:13,754] log.py->debug():97 -- DEBUG -- BASEMESH VERSION: hm08
[2020-05-31 17:36:13,754] log.py->debug():97 -- DEBUG -- IS BUILT (FROZEN): No
[2020-05-31 17:36:13,754] log.py->debug():97 -- DEBUG -- IS RELEASE VERSION: No
[2020-05-31 17:36:13,754] log.py->debug():97 -- DEBUG -- DEFAULT ENCODING: utf-8
[2020-05-31 17:36:13,754] log.py->debug():97 -- DEBUG -- FILESYSTEM ENCODING: utf-8
[2020-05-31 17:36:13,754] log.py->debug():97 -- DEBUG -- STDOUT ENCODING: cp1250
[2020-05-31 17:36:13,754] log.py->debug():97 -- DEBUG -- LOCALE PREFERRED ENCODING: cp1250
[2020-05-31 17:36:13,754] log.py->debug():97 -- DEBUG -- WORKING DIRECTORY: D:\Program Files\makehuman-community\makehuman
[2020-05-31 17:36:13,754] log.py->debug():97 -- DEBUG -- HOME LOCATION: C:/Users/damia/Documents
[2020-05-31 17:36:13,754] log.py->debug():97 -- DEBUG -- PYTHON PATH: ./;./lib;./apps;./shared;./apps/gui;./core;D:\Program Files\makehuman-community\makehuman;C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.7_3.7.2032.0_x64__qbz5n2kfra8p0\python37.zip;C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.7_3.7.2032.0_x64__qbz5n2kfra8p0\DLLs;C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.7_3.7.2032.0_x64__qbz5n2kfra8p0\lib;C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.7_3.7.2032.0_x64__qbz5n2kfra8p0;C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.7_3.7.2032.0_x64__qbz5n2kfra8p0\lib\site-packages
[2020-05-31 17:36:13,754] log.py->debug():97 -- DEBUG -- DLL PATH: C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.7_3.7.2032.0_x64__qbz5n2kfra8p0;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Common Files\Autodesk Shared\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;D:\Program Files\Process Lasso\;D:\Program Files\Git\cmd;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\Users\damia\AppData\Local\Microsoft\WindowsApps;D:\Program Files\Microsoft VS Code\bin
[2020-05-31 17:36:13,754] log.py->debug():97 -- DEBUG -- SYS.VERSION: 3.7.7 (tags/v3.7.7:d7c567b08f, Mar 10 2020, 11:52:54) [MSC v.1900 64 bit (AMD64)]
[2020-05-31 17:36:13,754] log.py->debug():97 -- DEBUG -- SYS.PLATFORM: win32
[2020-05-31 17:36:13,754] log.py->debug():97 -- DEBUG -- SYS.EXECUTABLE: C:\Users\damia\AppData\Local\Microsoft\WindowsApps\PythonSoftwareFoundation.Python.3.7_qbz5n2kfra8p0\python.exe
[2020-05-31 17:36:13,754] log.py->debug():97 -- DEBUG -- PLATFORM.MACHINE: AMD64
[2020-05-31 17:36:13,756] log.py->debug():97 -- DEBUG -- PLATFORM.PROCESSOR: AMD64 Family 23 Model 8 Stepping 2, AuthenticAMD
[2020-05-31 17:36:13,756] log.py->debug():97 -- DEBUG -- PLATFORM.UNAME.RELEASE: 10
[2020-05-31 17:36:13,756] log.py->debug():97 -- DEBUG -- PLATFORM.WIN32_VER: 10 10.0.18362 SP0
[2020-05-31 17:36:13,756] log.py->error():111 -- ERROR -- Could not create debug dump
File "D:\Program Files\makehuman-community\makehuman\makehuman.py", line 203, in debug_dump
debugdump.dump.reset()
File "./lib\debugdump.py", line 144, in reset
import numpy
ModuleNotFoundError: No module named 'numpy'
chunkypuding
Re: Make human will not launch on win 10
Postby MrSloan » Sun May 31, 2020 6:44 pm
I also have trouble to launch the 1.2.0 beta on windows 10
it worked once, but not after reinstalling it.
with 1.1.1 (which runs on my w10) i have the trouble that it cannot complete the database synchronization download.
maybe trying two versions is an issue in the registry or something? I also removed visual studio, after that makehuman python was not starting. maybe that has to do with it?
any solutions?
edit
ah choosen 1.2.0 beta does work once i uninstalled, restarted and use the startmenu start button, instead of desktop link.
MrSloan
Postby RobBaer » Mon Jun 01, 2020 6:47 am
chunkypuding wrote:Hello
LOG
import numpy
Your problem seems to be that you have not added numpy to you python installation.
The following are the minimum required dependency versions for MakeHuman Community 1.2.0:
Python: 3.6.4 or higher
PyQt: 5.10.0 to 5.12.x. 5.14 will not work
NumPy: 1.13.0 or higher
PyOpenGL: Any modern version will work, including the one used for MakeHuman 1.1.x
Postby RobBaer » Mon Jun 01, 2020 6:52 am
MrSloan wrote:ah choosen 1.2.0 beta does work once i uninstalled, restarted and use the startmenu start button, instead of desktop link.
This is unfortunate limitation of the installer. If you like starting from the desktop, right click the MH icon in start, choose more, and choose open file location. Now copy the shortcut to your desktop if you like.
Postby RobBaer » Mon Jun 01, 2020 6:55 am
LOG
import numpy
You seem to be running from source on Windows. Your problem seems to be that you have not added numpy to you python installation.
An alternative would be to download the nightly build. http://download.tuxfamily.org/makehuman/nightly/ which has built in python with all dependencies.
Postby chunkypuding » Mon Jun 01, 2020 10:43 am
Following MrSloan advice
Everything works it seams that the installer just creates a faulty desktop shortcut.
This is the build that i have installed, from this exact link and it was creating my issue.
makehuman-community-1.2.0-beta1-windows.zip
Thank you for support
chunkypuding
Postby joepal » Mon Jun 01, 2020 2:08 pm
Actually, all this is worrisome, as I recently pushed a fix intended to make desktop shortcuts work when installing for all users.
What does the desktop shortcut point to on your machine?
Postby RobBaer » Tue Jun 02, 2020 2:05 pm
joepal wrote:Actually, all this is worrisome, as I recently pushed a fix intended to make desktop shortcuts work when installing for all users.
Didn't realize you had done this. Tested with fresh install. Here is what I got:
"E:\Program Files\makehuman-community\Python\pythonw.exe" E:\Program Files\makehuman-community\mhstartwrapper.py
"E:\Program Files\makehuman-community\makehuman"
The problem is path names with spaces. Need quotes around python argument in first shortcut argument.
If you want a similar approach for "just for me" user installs, put %USERNAME% where the username would be and Windows will pick it up from the environment. Sort of the Windows version of tilde, except messier. Should work.
