Shoe added not appearing in tab filter
Postby JefersonGF » Thu Dec 19, 2019 2:29 pm
I downloaded all the files (MHCLO, obj, MHMAT and optional thumb file) of a shoe model in the Assets section, the model appears in the MakeHuman and works great, but when I choose "Female" in the tab filter options, the model not appear.
I renamed the folder to: female_shoe01, and all the files into this folder using the prefix "female_". This folder is in "makehuman\data\clothes\". I'm using the 1.1.1 version. Everything works normally, the only problem is that the object not appear when ""female option in the tab filter is checked. Any Help Would Be Appreciated and Thank In Advance! (using google translate)
JefersonGF
Re: Shoe added not appearing in tab filter
Postby loki1950 » Thu Dec 19, 2019 6:12 pm
The filter works on tags within the .mhclo the file not on the file name at all BTW it's just a text file it's format is described in our wiki and there is a way on adding Tags to assets within MH it's a plug in that is not activated by default.
Postby JefersonGF » Fri Dec 20, 2019 8:02 pm
loki1950 wrote:The filter works on tags within the .mhclo the file not on the file name at all BTW it's just a text file it's format is described in our wiki and there is a way on adding Tags to assets within MH it's a plug in that is not activated by default.
Thank you for help :D
JefersonGF
