Dumb, cannot find how to add assest or comm. tab in alpha
Postby Koko78 » Thu Dec 19, 2019 5:31 am
Hi all
Stupid noob Q:
I have installed the alpha 1.2.0 hoping it would resolve this issue of having to paste / tweak the interface for adding detailed anatomy (YUP, ongs and vags) using the tip home/username/makehuman/v1/data/proxymeshes from the stable release.
BTW I did find this: http://www.makehumancommunity.org/proxy ... talia.html
No dice.
I'm in a windows OS 10 pro 64b environment.
My directory: C:\makehuman\data\proxymeshes
I know, dumb question but can't find a simple answer.
TIA
Koko78
Re: Dumb, cannot find how to add assest or comm. tab in alph
Postby joepal » Thu Dec 19, 2019 8:02 am
Did you try https://youtu.be/ra_pkb9IdeI ?
As far as I know it works fine with proxies. It should be available under the community tab.
Postby RobBaer » Thu Dec 19, 2019 8:06 am
Koko78 wrote:Hi all
Stupid noob Q:
No dice.
TIA
Not sure I quite get your question, but for 1.2.0 :
should probably be
home/username/makehuman/v1py3/data/proxymeshes
Genitalia can be found in user assets using the asset downloader on the community tab. Filter on skin and proxy type.
Postby joepal » Thu Dec 19, 2019 9:29 am
Or is the community tab not appearing for you? In that case I would like to see the logs http://www.makehumancommunity.org/wiki/ ... _report%3F
Postby Rostropovich » Tue May 18, 2021 5:16 am
Hallo! Love this software and I just can say a big THANK YOU!
But I really don't understand the problem with the genitals. I have been following since three hours all the indications to install them, and it's impossible.
I have downloaded the proxy files and put them in my user's directory, also inside the app (oppening "show packages"), I also found this video in the forum (I think I read all threads about this theme) https://youtu.be/ra_pkb9IdeI
and I followed it's indications and downloaded and synchronized ... later I looked for the right proxys and install them and the app said finshed download and ... desperation.
Can anyone let me know how to proceed??
Thanks a lot
Rostropovich
Postby punkduck » Wed May 19, 2021 6:15 pm
look in the other folder where you asked the question also ... worst case test it manually with a normal download with the browser. These are only files which should appear at the right place.
Postby Rostropovich » Wed May 19, 2021 10:00 pm
Sure I downloaded the files from several sources, several times, ... I spent around 3 hours only with this, I never give up, I always get what I want (at least with my computer), but I swear, this time I think I have to surrender and be a "acceptable for facebook guy" ... there must be something I am doing wrong, but I really have no clue.
Rostropovich
Postby joepal » Thu May 20, 2021 5:38 am
I repeated the process now, and did not see anything strange. Steps taken:
- start mh 1.2.0
- go to the community -> download assets tab
- select proxy as asset type
- search for genital
- select "adult male genitalia" in the list
- click download
- go to the geometries -> topologies tab
- select the "adult male genitalia" proxy
- end result: toon in window has penis
That it works for me is obviously not the same as working for everyone, but I'll need to know which step it is that fail. Does it not appear in the topologies list? Does nothing happen when you click it? Is there an error message in the logs? (http://www.makehumancommunity.org/wiki/ ... _report%3F)
Postby Rostropovich » Fri May 21, 2021 7:12 pm
joepal wrote:I repeated the process now, and did not see anything strange. Steps taken:
- start mh 1.2.0
- click download
OMG!
Really, one thousand tanks, I mean thanks for describing the steps one by one, I was doing all that, but then I didn't know "- go to the geometries -> topologies tab", since I was always looking in "Modeling -> Gender -> Genitals", and i was always stuck there.
Thank you very muuuchhhhh ... I have genitalsssss ... Fuck you facebook and instagram!! Hhahahhaahaa ... Hurray for make human!!
Rostropovich
