Clean white stull in Germanic Cloth
Postby Liverpinguino » Wed Sep 25, 2019 6:12 am
Hello There:
I imported from makehuman an avatar with the germanic clothes but the outcume in the cothes comes with white degradattion, not sure why is that happening and how can I solve it .
Thanks a lot.
Liverpinguino
Re: Clean white stull in Germanic Cloth
Postby RobBaer » Wed Sep 25, 2019 10:45 am
Admitting I don't know what "clean white stull" means relative to your goal...
If you want all green, It looks like the green on your texture is a little small. You might extend the green areas of your UV map to remove the white.
Conversely, if you wanted white separators without blended jaggies, it might be that you started with a texture map that had too low of a pixel density. Try increasing the height and width of your texture before drawing the green.
Postby Liverpinguino » Wed Sep 25, 2019 7:29 pm
"Clean white stuff" is what I meant. Apologies for my english.
I imported the cloth from http://www.makehumancommunity.org/cloth ... othes.html
"You might extend the green areas of your UV map to remove the white" any tutorial or indication where I can learn how to do that.
Thanks a lot for you answer.
Liverpinguino
Postby RobBaer » Mon Sep 30, 2019 12:57 am
Perhaps I should have asked for more detail on what you did. On Windows 10 with MH 1.2.0alpha3 and Blender 2.80, using mhx2 export and import I got a result like this:
germanic
