Impossible de charger les vêtements ou les cheveux
Postby KANGOUROU224 » Fri Aug 23, 2019 2:18 pm
Bonjour,
Impossible de charger les vêtements de "User contributed assets" dans Make Human sur le modèle principal.
Je fais un double clic,...rien ne se passe.Un message d'erreur s'affiche en bas,mais je n'ai pas le temps de le lire...il disparait aussitôt... :roll:
KANGOUROU224
Re: Impossible de charger les vêtements ou les cheveux
Postby wolgade » Sat Aug 24, 2019 2:58 pm
Your chances of getting help might improve significantly if you decided to post in English.
The error message you mention should also appear in the log file. It's a good idea to post this log file here. Otherwise it's almost impossible to tell what goes wrong when you try to load clothes or hair.
Postby KANGOUROU224 » Mon Aug 26, 2019 8:35 pm
Hi !
where is the log? I look at down but the text is disappeared in one second ! :roll:
KANGOUROU224
Postby wolgade » Mon Aug 26, 2019 9:37 pm
It depends on the version of MH you use. Using 1.2.0 alpha3 on Windows you should find a file called makehuman.log under "My Documents\makehuman\v1py3". Of course, "My Documents" will be named differently on a system with French language settings. Keep in mind that windows hides file extensions by default.
Whatever OS or version of MH. You're looking for a file called makehuman.log.
Postby KANGOUROU224 » Wed Aug 28, 2019 2:55 pm
I FOUND THIS:
Unloading plugin 3_libraries_eyebrows
Unloaded plugin 3_libraaries_eyebrows
I HOPE THAT IS GOOD
to day,I found out what was wrong. I simply forgot to download from the MH community site, the Obj files;Thank you for your help because putting the files back in the right place, allowed me to dig more into v1 etc.
KANGOUROU224
Postby wolgade » Fri Aug 30, 2019 12:12 pm
Sorry for the late reply.
The clothes you're trying to load are simply not found. Do they exist at the right place? There's something strange with your installation. You have a working directory set to
C:\Users\Utilisateur\Documents\make human
On the other hand there exists a directory called
C:\Users\Utilisateur\Documents\makehuman\v1\data\clothes\
v1\data\clothes should exist under your working directory. Have a look inside your Documents folder. Do you have two folders called "makehuman" and "make human"? If so, this mess should be cleaned up. To play it safe, make sure the remaining folder is called "makehuman" and not "make human". MH might make assumptions about this folder name internally.
Even more weird:
KANGOUROU224 wrote:SYS.EXECUTABLE: C:\Users\Utilisateur\Documents\make human\makehuman.exe
This is a strange place to install a program. How did you install? Sorry for the bunch of questions, but I never installed MH on Windows.
Postby KANGOUROU224 » Fri Aug 30, 2019 3:39 pm
Hello,
I changed the name make human to makehuman because I did have 2 files; I still have a "makehuman" folder in which I put all the content of v1. but it didn’t change anything. I still can’t load clothes from the Community. to day ,I found out what was wrong. I simply forgot to download from the MH community site, the Obj files;Thank you for your help because putting the files back in the right place, allowed me to dig more into v1 etc. :)
KANGOUROU224
