I need help installing add ons on Blender
Re: I need help installing add ons on Blender
Postby joepal » Mon Jul 29, 2019 9:23 am
I think possibly you're confusing MHX2 and the importer in MPFB (makehuman plugin for blender). These are unrelated.
MHX2 is the old style file export format. You use this by exporting a file in makehuman and then importing that file in blender. MHX2 is developed independently of makehuman, and development has stalled a bit lately. To get a version that works with blender 2.80, check out Aranuvir's fork at https://bitbucket.org/Aranuvir/mhx2-mak ... downloads/
MPFB is the new style connection between makehuman and blender. It does not use any file exports at all. Instead it enabled blender to communicate directly with blender. To enable this in blender you should install the plugin zip found here: https://github.com/makehumancommunity/m ... stribution, or use the same file shipped with the alpha.
Postby MHB29 » Mon Jul 29, 2019 9:23 pm
Joepal,
Thanks for your help, I have succeeded to MPFB. BTW, I would like to install https://bitbucket.org/Aranuvir/mhx2-mak ... downloads/ .
Do you have a link for some tutorial please ?
MHB29
Postby MHB29 » Wed Jul 31, 2019 8:06 pm
[url=https://www.noelshack.com/2019-31-3-1564603449-probleme-importation-mh2x-addo :? n-aranuvir.png]Image[/url]
MHB29
Postby MHB29 » Wed Jul 31, 2019 8:10 pm
MHB29
Postby loki1950 » Fri Nov 29, 2019 12:29 am
Widows in it's infinite wisdom makes the all folders under AppData hidden by default you have to change that behaviour by allowing explorer to view them their reasoning is that normal users will screw things up which they just might ;)
Postby Aranuvir » Fri Nov 29, 2019 1:51 am
https://docs.blender.org/manual/en/late ... ayout.html
BTW, zip files downloaded from a software development platform are a clone of the repository, rather than a suitable add-on package. Usually zip files need to be recreated from subfolders.
