There is no default model
Postby Lucky8 » Tue Mar 05, 2019 1:35 am
Hi! Is the first time I use this software and the only thing I was able to do is open it :mrgreen: I was expecting to find a default model to start playing with setting but there is only a white canvas and touching every button doesn't seems to be the way to go. I took a pass over the FAQ but didn't find anything about default model. Also google a few tutorials but I saw when other people open MakeHuman the default model is always loaded so ¿how to procede?
Lucky8
Re: There is no default model
Postby loki1950 » Tue Mar 05, 2019 3:12 am
If you are getting a blank white workspace I suspect you are on Win 10 with a AMD GPU try our latest alpha release from here http://download.tuxfamily.org/makehuman ... y/a3rc.zip just unzip and run the installer then MH will be available on your Start Menu.
Postby Lucky8 » Tue Mar 05, 2019 5:08 pm
loki1950 wrote:If you are getting a blank white workspace I suspect you are on Win 10 with a AMD GPU try our latest alpha release from here http://download.tuxfamily.org/makehuman ... y/a3rc.zip just unzip and run the installer then MH will be available on your Start Menu.
Yes :) I'm on W10 some insider build ( on an AMD discrete GPU ) and testing " makehuman-community-1.2.0-alpha2-win32" . I thought that was the latest release. Now downloading the one you point out! Thank you. Back later to tell you how it goes
EDIT: Works great! Thank you again for your help
Lucky8
Postby joepal » Thu Mar 07, 2019 12:57 pm
The link loki posted is to a release candidate of alpha 3. It's possible we'll rename it to alpha 3 eventually unless something pops up. In any which way, the final release of alpha 3 will be very similar to a3rc.
Postby Aranuvir » Thu Mar 07, 2019 5:30 pm
The downlaod page links to a2
