Saving IK/FK switch in different actions
Postby brianpk » Mon Aug 20, 2018 7:57 pm
Hello,
I have created 2 actions using the MHX2 rig. The first is a single leg stance, where the left arm, right arm, and right leg are set as FK and the left leg is set as IK. I have a different action that is a walking animation, where all the limbs are set to IK. However, I can't figure out how to save the IK/FK settings to each action. For example if I select the walking animation where everything is set to IK, and then I switch to the single leg stance animation, all of the settings are still set to IK instead of only the left leg being IK. Is there a way to save this so it switches automatically? I tried baking the animation but that didn't seem to work.
I attached the blend file if you need to look at it. Thanks so much.
Brian
DraftThreeMaleSLSblend.blend
(5.95 MiB) Downloaded 413 times
brianpk
