Jnjngfvgf wrote:So I found the solution. If the file name is too long or descriptive it wont be reloaded when you reopen the makehuman file. I had no idea something like that has an actual impact on the load. glad it was a simple fix.
First, glad things are working.
It sounds like an undocumented problem that the file name length makes a difference. Windows used to have a maximum PATH length of 260 characters, but I think they changed that with Windows 10. Which Windows are you on? Could you give us an example of a name that fails and a replacement that makes it start working?
Even better, could you provide a full path for a target file that fails and its working equivalent?
