How to export w/out bones?
Postby javierdl » Mon Jan 11, 2010 5:58 pm
I just did my first export/import to Blender, yuppie! Thanks to mlferackers actually.
Once I had a closer look at the mesh I noticed it's filled with small diamonds-like shapes, I suppose they are meant to be bones in MH. But since I will add my own Armature (skeleton) in Blender I figure I should remove these shapes. They are a lot though.
Obviously the ideal thing would be if there was a way to export the mesh w/out these bones.
JDL
javierdl
Re: How to export w/out bones?
Postby monsey » Mon Jan 11, 2010 11:19 pm
I'm a fellow newb but I just seen a similar question in blender irc and they said the diamonds were used to help the computer make certain measurements and could be deleted after export. I have no idea about exporting without them though.
monsey
Postby Manuel » Thu Jan 14, 2010 3:09 pm
It's not possible to export the mesh without the joint markers, at the moment.
Best,
PS: They are the only elements with triangles (the rest of mesh is quads-only), and in future releases they will be not exported.
Postby ThomasL » Thu Jan 14, 2010 9:20 pm
It is easier to delete the joints if you first hide the mesh: in edit mode, select a vert, Ctrl-L, H. Then you can box-select all joints, except in the head area.
ThomasL
