Roygee wrote:Hi there - I've just downloaded Alpha 3 and need some help in getting started - I have been in 3d modeling for a reasonably long time and know my way around many apps - have also used previous versions of MakeHuman.
Firstly, does this version install, or do I have to run it from the .exe?
Secondly, how do I export an .obj? Have tried "E" as suggested by someone on this forum, but nothing happens. Have looked in the folder that contains the .exe - nothing.
Is there any sort of users manual - even if just rudimentary? About all I have managed to do is rotate and apply some morphs!
There's a quick start guide at
http://sites.google.com/site/makehumandocs/quick-startThis document is based on Alpha 1, the main changes since then are with the detailed anatomical modelling and with the addition of hair. Three are also some small GUI changes.
The Windows download just needs unzipping, then you run makehuman.exe to launch it.
There does seem to me to be a problem with the 'e' for export workaround in this Alpha 3 test release. It also doesn't look like the main export function on the file management screen is working yet. I get errors in module3d.py lines 1336 and 1385 in keyDown and keyUp "LookupError: no codec search functions registered: can't find encoding".
The rendering screen is able to generate renderman format and POV-Ray format files.
Regards,
Chris B.
