Edit:FoudAlpha 8 rig export, how to export with xonotic rig
Postby Animations4 » Wed Sep 04, 2013 5:19 pm
Edit: Found in Pose/Animate > Skeleton
How does one export with the xonotic rig in alpha 8, I can't find the option in the menu (but no options come up usually in export now for skel export), I see it in the svn tree, do I set it in a config file like the older makehumans?
Binary file plugins/3_libraries_skeleton/maintab.pyc matches
plugins/3_libraries_skeleton/skeletonlibrary.py: descr = self.amtOptions.loadPreset("xonotic", self.optionsSelector)
Animations4
Re: Edit:FoudAlpha 8 rig export, how to export with xonotic
Postby ThomasL » Thu Sep 05, 2013 8:55 am
It's in the Pose/Animate > Skeleton tab. No sure if this is the best placement though, since rig choice is very similar to geometry choice. But then again, a rig is not geometry.
I would be interested to know if it works. AFAIK, nobody has actually tested the Xonotic rig with Xonotic.
ThomasL
Postby Manuel » Thu Sep 05, 2013 9:20 am
ThomasL wrote:It's in the Pose/Animate > Skeleton tab. No sure if this is the best placement though, since rig choice is very similar to geometry choice. But then again, a rig is not geometry.
Indeed. Maybe we can move it in Geometry-->skeleton, since the skeleton is not a pose or an animation.
A note. As planned in our roadmap, the GUI will be unified as in the mockup below.
Postby duststorm » Fri Sep 06, 2013 5:01 pm
ThomasL wrote:I would be interested to know if it works. AFAIK, nobody has actually tested the Xonotic rig with Xonotic.
I did some work on the MD5 exporter some time ago, when communicating with Patrick who was experimenting with it.
But I have not heard from him in a while.
In fact he was looking into converting the MD5 mesh into xonotic's improved IQM format as well.
