Export to CAD formats
Postby salicioucrumb » Fri Aug 16, 2013 7:24 pm
Hi Everyone,
I'm a CAD modeler and I find it tedious to go through the conversion process in order to convert a MakeHuman file into a workable format for CAD programs such as Solidworks.
Would it be possible to incorporate the ability to export to formats such as IGES, STEP, and or Parasolid, even if the poses are then static after export?
salicioucrumb
Re: Export to CAD formats
Postby Manuel » Fri Aug 16, 2013 8:08 pm
Added in roadmap for alpha9.
http://makehuman.org/content/add_cad_support.html
Now it's matter to have enough resources to implement it.
Best,
Postby Rapscallion » Fri Aug 16, 2013 8:32 pm
Don't know if this is any help but, there is a program called mesh-to-solid. I looked at it a while back. I think it was a trial or demo version. As far as I can remember the meshes have to be closed and the normals of the facets have to be unidirectional before it can solidify. I don't know if mesh-to-solid allows mesh editing so that you can close the meshes but, you could pipeline them through Blender. Then again maybe that's the tediousness that you're talking about.
Can't Solidworks close and solidify meshes? One would think it could at the price it goes for.
Rapscallion
Postby duststorm » Sat Aug 17, 2013 1:07 am
Is there no export format available in MH that is possible to be imported in CAD software?
I think there is a good chance it is able to import wavefront OBJ, or callada (DAE) files.
Postby Manuel » Sat Aug 17, 2013 8:36 am
Obj should work indeed.
Postby Manuel » Sat Aug 24, 2013 11:31 am
salicioucrumb wrote:Hi Everyone,
Can you confirm wavefront obj is ok for your CAD application?
