POV-Ray path fault?
Posted: Thu Aug 08, 2013 6:41 pm
Hello,
I understand that the render options in MH are still experimental but the solution to this bug might be simple.
Don't know if any one else is aware of, or has experienced this but the POV-Ray render option gives me the following message box if I choose the export and render option:
POV-Ray not found
You don't seem to have POV-Ray installed or the path is incorrect.
This is despite having typed the correct path in the provided field.
I'm using POV-Ray version 3.62 and by default the executables (pvengine.exe and pvengine-sse2.exe) install to c:\program files\pov-ray for windows v3.62\bin
My insallation of POV-Ray works fine on its own.
Regards to all.
POV-Ray not found
Regards to all.
