suggest, tip for have the full clothes (without skin)
Postby dark poulpo » Thu Jan 31, 2013 10:50 pm
hi, here a tip to draw the clothes with the hidden skin...
render
you make edit the fragment shader to add the masks files and draw the body in last (after the clothes)
you must adapt my example to go with the current shader
eg
vec4     vmask0;
vec4     vmask1;
uniform sampler2D mask0;
uniform sampler2D mask1;
uniform bool b_mask0;
uniform bool b_mask1;
     vec4 fragmentColor = vColor;
   vec4 mask0v = vmask0;
    if (b_mask0) mask0v = texture2D(mask0, vTextureCoord.st);
   if (mask0v.r == 0.0 && mask0v.g == 0.0 && mask0v.b == 0.0) mask0v.a = 0.0;
   vec4 mask1v = vmask1;
    if (b_mask1) mask1v = texture2D(mask1, vTextureCoord.st);
   if (mask1v.r == 0.0 && mask1v.g == 0.0 && mask1v.b == 0.0) mask1v.a = 0.0;
    fragmentColor.a = transparentv.a * mask0v.a * mask1v.a;
    gl_FragColor = vec4(fragmentColor.rgb * gl_FragColor.rgb, fragmentColor.a);
texture draw
enable(gl.BLEND);
blendFunc(gl.SRC_ALPHA, gl.ONE_MINUS_SRC_ALPHA);
and
    gl.enable(gl.DEPTH_TEST);                               // Enable depth testing
    gl.depthFunc(gl.LEQUAL);                                // Near things obscure far things
   gl.colorMask(true, true, true, true);
    gl.clear(gl.COLOR_BUFFER_BIT|gl.DEPTH_BUFFER_BIT);
mask2
mask1
dark poulpo
