Daz Studio / Poser
Daz Studio / Poser
Postby Tommysk » Tue Sep 23, 2008 1:28 pm
Hi, will we be able to export future MH characters to DAZ Studio or Poser ?
Actually, the main question is "could future MakeHuman export to the unimesh file format" ?
Tommysk
Re: Daz Studio / Poser
Postby pistacja » Tue Sep 23, 2008 1:55 pm
Daz reads obj files if I'm not mistaken, so you can import them even now and Dad (of on the user here) had at least some success in using MH and poser:
viewtopic.php?f=2&t=26&st=0&sk=t&sd=a
This post was made thanks to Me, Myself and I.
pistacja
Postby KrownProducts » Thu Oct 02, 2008 6:16 pm
pistacja wrote:Daz reads obj files if I'm not mistaken, so you can import them even now and Dad (of on the user here) had at least some success in using MH and poser:
DAZ and Poser do indeed import the MakeHuman obj. files. However, the bone/rigging does not import and you are unable to pose the figure. I am hoping the newest MakeHuman release will have Poser bone system compatibility. Currently, to bring a boned figure into DAZ or Poser, I need to use a program like ToolBox II from Greenbriar Studios to add the Poser bones to the obj file. I have successfully created many figures and props using the following...
The process is;
1. Create the figure in MakeHuman (I am using ver 9.1) and export as an obj. file.
2. Import the obj. file into ToolBox II. Add an empty Poser mesh to hold the bones. Then copy or create the bone rigging and export the final combined figure to a Poser character.
3. ToolBox II creates all the files needed for DAZ|Studio with the exception of the thumbnail, which I create from a render of the new character.
Links and samples can be found on my website.
http://www.krown-products.net/meshworks/index.html
Hope this helps.
KrownProducts
Unimesh
Postby Tommysk » Wed Dec 10, 2008 11:06 am
Actually, the main question is "could future MakeHuman export to the Daz Studio / Poser unimesh file format" ?
Tommysk
Postby pistacja » Wed Dec 10, 2008 12:18 pm
If the file format is documented then I can imagine someone writing a python export plugin for it... once the python plugin thingy is there
pistacja
Postby Tommysk » Mon Dec 15, 2008 10:38 am
That would be extraordinary !
Tommysk
Postby kervala » Tue Dec 16, 2008 12:25 pm
Can't you use COLLADA with Poser (or Poser pro) ?
kervala
Postby AShenwraith » Thu Feb 26, 2009 3:06 pm
I think the first goal would be to import, then once you know the file format well you can easily export.
AShenwraith
Postby samo » Fri Apr 17, 2009 1:35 am
If Makehuman can have more compatibilty with Poser or DaZ, it will be great !
samo
Postby abraess » Tue May 12, 2009 11:52 am
Hallo,
I would be happy if can make with Makehuman and Blender the same as Daz. Because can pay so much for all the things but I´m will building them self. :) I look forward to Makehuman 1.0.
Andreas Braess
abraess
