Demande
Demande
Postby Beberto08400 » Fri Apr 12, 2019 2:51 pm
Bonjour quelqu'un peut il créer dans ce style la svp merci cordialement
Beberto08400
Re: Demande
Postby Elvaerwyn » Sat Apr 13, 2019 10:12 pm
Allo! Greetings! Out of curiosity are you a blender user, or just using makehuman at present?
Re: Demande
Postby Elvaerwyn » Sun Apr 14, 2019 1:31 am
Allo again, the pumps were addressed now in a posable form, there is much to do in this area however. Will upload more if and when we address this issue, if we find this is not something that can be done I will share my shoe library in zip form very soon.
http://www.makehumancommunity.org/cloth ... umps1.html
Re: Demande
Postby Beberto08400 » Sat Apr 20, 2019 9:17 pm
J'utilise Bender pour créer des poses. Merci vos chaussure s'adapte par contre les nouvelle comme Elvs Laceback Heels1 reste figé au sol et ne s'ajuste pas sur jambes pliés par exemple... Si vous avez solutions j'en suis preneur. J'utilise Blender mais amateur
Beberto08400
Re: Demande
Postby punkduck » Sat Apr 20, 2019 10:39 pm
Beberto08400 wrote:J'utilise Bender pour créer des poses. Merci vos chaussure s'adapte par contre les nouvelle comme Elvs Laceback Heels1 reste figé au sol et ne s'ajuste pas sur jambes pliés par exemple... Si vous avez solutions j'en suis preneur. J'utilise Blender mais amateur
Please have a look at this article:
http://www.makehumancommunity.org/forum/viewtopic.php?f=14&t=17208
I am working with Elv and we have developed different methods. The "Laceback Heels" were made like in method (3), you use a custom target which you can download from the assets. So the target will push the feet into the shoes. The target looks more real than the 15cm pose you can create with bones.
Elv will do another version using method (3) for the stiletto pumps. The method we tried in (2) is rather complicated because we have to deform everything with proportional edit and in the end we both hoped that it will reshape with foot in the pose it was build for ...
I am pretty sure we will use method (3) with targets for further shoes, because that is a lot easier ...
Re: Demande
Postby Beberto08400 » Sun Apr 21, 2019 7:51 am
J'utilise l'actif pour les poses debout cela fonctionne. Je parlait des poses avec par exemple une jambe levée ou pose couchée les chaussures reste figée au sol comme si la pose était debout donc les chaussures sont détachée du pied et ne suive pas.
Beberto08400
Re: Demande
Postby Beberto08400 » Sun Apr 21, 2019 8:00 am
Exemple
Ne suit pas
Beberto08400
Re: Demande
Postby Beberto08400 » Sun Apr 21, 2019 8:03 am
Exemple. Les chaussures reste figée
Figée
Beberto08400
Re: Demande
Postby punkduck » Mon Apr 22, 2019 7:11 pm
please reload these shoes, in all cases both shoes were accidentally bound to one foot. Work for additional targets is not yet finished, but it will allow more characters to wear the shoes in future.
