create poses using script
Re: create poses using script
Postby ShatteredEssence » Mon Jun 12, 2017 2:44 pm
Indeed, I cut the code to like this
import animation
import random
from core import G
from bvh import BVH
import matrix as m
def generate_poses(human, human_name):
    from bvh import BVH
    import matrix as m
    skeleton=human.skeleton
    bones=skeleton.getBones()
    b=BVH()
    b.fromSkeleton(skeleton, None, False)
    anim=b.createAnimationTrack(skeleton, name=human_name)
    rotmatrix=m.rotx(30)
    change=rotmatrix[:5, :2]
    for boneNr in range(len(bones)):
        boneName=bones[boneNr].name
        animData=anim.data[boneNr]
        if boneName == "upperarm02.L":
            anim.data[boneNr]=change
    human.addAnimation(anim)
    human.setActiveAnimation(anim.name)
    human.refreshPose()
    return human
Well, it runs, but I can't see any differences
ShatteredEssence
Postby dugarsumit » Mon Jun 12, 2017 2:50 pm
Right. I am afraid you will need to code that part yourself. It won't be tough :)
dugarsumit
Postby ShatteredEssence » Mon Jun 12, 2017 3:04 pm
dugarsumit wrote:Right. I am afraid you will need to code that part yourself. It won't be tough :)
Yeah. Just point me what part? Random? How do i correctly call this funcrion, lets say wo random for now.
ShatteredEssence
Postby dugarsumit » Mon Jun 12, 2017 3:12 pm
variable named 'change' that contains rotation matrix defines the change that will happen to the bone. You just need to pass random matrix values into this variable. (Y)
dugarsumit
Postby ShatteredEssence » Mon Jun 12, 2017 4:16 pm
I'am confused.
rotmatrix=m.rotx(30) - here you assig to rotmatrix some kind of matrix, what 30 stands for?
change=rotmatrix[:3, :4] here you take first 3 lines and gets first 4 rows of that lines?
Can't seem to find anything in api reference
http://www.makehumancommunity.org/api/s ... tml?q=rotx
Are there any descent documentations?
ShatteredEssence
Postby dugarsumit » Mon Jun 12, 2017 4:47 pm
There is no documentation as far as I remember. I had to struggle a lot when I was figuring out this.
rotmatrix=m.rotx(30) : It means 30 degree rotation around x-axis
change=rotmatrix[:3, :4] : It's a python syntax which means pick first 3 rows and first 4 columns.
Hope this helps :)
dugarsumit
Postby ShatteredEssence » Mon Jun 12, 2017 5:03 pm
dugarsumit wrote:There is no documentation as far as I remember. I had to struggle a lot when I was figuring out this.
Hope this helps :)
It does helped ) In a way. Maybe you can clarefy for me pivots of the bones transformation.
In attachment below from 3d app I have a finger rotated by a degree.
I have a code for this like
import animation
import random
from core import G
from bvh import BVH
import matrix as m
Meanwhile in attachment from debug skeleton i see that X pyvot is set correctly, and adding rotx offset should have bended the finger normaly towards inner part of the hand.
def generate_poses(human):
    from bvh import BVH
    import matrix as m
    b=BVH()
    anim=b.createAnimationTrack(skeleton, name="Tst")
    rotmatrixx=m.rotx(50)
    rotmatrixy=m.roty(0)
    rotmatrixz=m.rotz(0)
    rotmatrix=rotmatrixx*rotmatrixy*rotmatrixz
        if boneName == "finger2-1.R":
    human.refreshPose()
    return human
human = G.app.selectedHuman
human=generate_poses(human)
And the result is wierd, bone kinda rotated oddly.
ShatteredEssence
Postby ShatteredEssence » Mon Jun 12, 2017 5:39 pm
I guess the key to pivots is
def rotate(a, xyz):
x, y, z = normalize(xyz)
s, c = _sincos(a)
nc = 1 - c
return np.matrix([[x*x*nc + c, x*y*nc - z*s, x*z*nc + y*s, 0],
[y*x*nc + z*s, y*y*nc + c, y*z*nc - x*s, 0],
[x*z*nc - y*s, y*z*nc + x*s, z*z*nc + c, 0],
[ 0, 0, 0, 1]])
But I cant seem to get it working propperly. Have you used this one?
ShatteredEssence
Postby ShatteredEssence » Mon Jun 12, 2017 7:05 pm
Well. After a few hours of hamering my head agains keyboard i must state: I have comletly no ide how to use local pivots of the bones, shown in debug skeleton.
ShatteredEssence
Postby dugarsumit » Tue Jun 13, 2017 5:34 am
I am afraid I don't have any idea about that pivot thing you are talking about. :(
dugarsumit
