Romantic female haircut with bow tie of hair
Re: Romantic female haircut with bow tie of hair
Postby joepal » Sun Dec 20, 2015 9:03 am
MTKnife wrote:
The choice of what, if I may ask?
Yeah, I kind of wondered that too. :-)
Postby loki1950 » Sun Dec 20, 2015 5:31 pm
I have been involved in Open source development for about 10 years now so it's referencing choice of free software.
Postby learning » Sun Dec 27, 2015 7:37 pm
I have to admit, outside certain very particular contests it looks like mockery or bitter sarcasm. Sadly, the amount of choice in Free Software still leaves a lot to be desired.
learning
Postby loki1950 » Sun Dec 27, 2015 10:08 pm
So it's a quixotic quest so why not dream big.
Postby grinsegold » Thu Dec 31, 2015 2:56 pm
loki1950 wrote:Hi grinsegold just tried to export the bow tie hair with MHX2 but the export thru an error it does not like accents they are not ascii so you might change the texture file names so the clueless don't complain 8-) Easy enough for me to do locally I do like both of your contributions as they have a formal feel to them.
Thanks Loki for the hint. Changed the names of the textures, including those inside the mHmat-file of course. It's good to have someone less clueless than me around to watch over the things i release. I would like to have a copy of you here on my shelf. So handy to know what one does with his pc. Maybe one day you explane me why i can't log in as root while i'm in a guest session in linux, to start with. No, no, that was no help request. But actually there's something you can do for me and for all the other clueless: Someone seemed to have similar export problems with my corset. But the texture's name doesn't seem to be the problem. Any idea?
grinsegold
Postby grinsegold » Thu Dec 31, 2015 3:17 pm
MTKnife wrote:Yes, I can always edit the hair myself, but the more I have to do for myself, the less advantage I gain from using someone else's asset rather than doing it myself.
It's the opposite - there's nothing more to gain from than being forced to do it the hard way.
grinsegold
Postby joepal » Thu Dec 31, 2015 3:33 pm
grinsegold wrote:Maybe one day you explane me why i can't log in as root while i'm in a guest session in linux, to start with. No, no, that was no help request.
The guest user is most likely not listed in /etc/sudoers. :-)
(just a guess, not knowing what your system looks like)
Postby joepal » Thu Dec 31, 2015 4:36 pm
grinsegold wrote:Someone seemed to have similar export problems with my corset. But the texture's name doesn't seem to be the problem. Any idea?
The corset works for me via MHX.
If there's a log output showing what the error is, I might be able to provide some input. But from the comment on the upload, all the info available is that it "does not export out of MakeHuman using MHX2". Which isn't enough to go on.
Postby loki1950 » Thu Dec 31, 2015 4:46 pm
I have used the mhx2 export on the corset and it works for me as well apart from some breast showing thru the model I used needs the corset big time ;) so will have to move some vertexes in blender.
Postby joepal » Thu Dec 31, 2015 4:48 pm
loki1950 wrote:I have used the mhx2 export on the corset and it works for me as well apart from some breast showing thru the model I used needs the corset big time ;) so will have to move some vertexes in blender.
Yeah, I just wrote a hint about that: viewtopic.php?f=20&t=13022
