Simple gloves
Simple gloves
Postby learning » Mon May 04, 2015 1:45 am
I wonder why there's no glove helper in MakeClothes? Well, anyway I made a pair of simple gloves for MH based on a part of basic human mesh. It's very simple, no texturing to speak of, just a copy of hand with a bit of cleanup/smoothing/sculpting. In case anyone would find it useful to build upon, I'll share it:
http://www.mediafire.com/download/e722z ... /gloves.7z
In case anyone needs it, here's the "source" i.e. blender file with human mesh and the model:
http://www.mediafire.com/download/lo039 ... st-3.blend
Enjoy.
learning
Re: Simple gloves
Postby duststorm » Wed May 06, 2015 6:45 pm
learning wrote:I wonder why there's no glove helper in MakeClothes?
I think it's not needed, you can fit to the hands directly.
Re: Simple gloves
Postby learning » Fri May 08, 2015 8:57 am
Well, I found out it's not that easy. At least not for me, of course I'm hardly the most competent 3d artist…
learning
Re: Simple gloves
Postby brkurt » Fri May 08, 2015 2:18 pm
learning wrote:Well, I found out it's not that easy. At least not for me, of course I'm hardly the most competent 3d artist…
The problem is easily solved in Blender:
(1) Export the model as a wavefront object;
(2) Create an edge loop on the arm where you want the glove to end (or the one past that);
(3) Delete that loop, and 'Ctrl L' to select the all the linked vertices in the body (you won't need it now);
(4) Here's the tricky one: select the hands that remain and do 'Alt S .05' (this will grow the hands along the mesh normals);
(5) Add a Solidify modifier to the mesh, and set thickness for -.05 (the negative makes the 'glove' expand out).
Here is a screenshot:
and the blend file:
http://www.geekopolis.ca/blender/learningGloves1_274.blend
Re: Simple gloves
Postby learning » Sun May 10, 2015 5:24 am
Okay, and how do you get rid of the fingernails etc sculpting?
learning
Users browsing this forum: Google [Bot], MSN [Bot] and 1 guest
