Numerical input values
Posted:
Tue Apr 28, 2015 12:05 pm
by bry
Would be great to be able to see the values as numbers, instead of just sliders, and also to be able to enter exact values.
Thanks.
Re: Numerical input values
Posted:
Sun May 03, 2015 10:53 am
by zoiner
Take a look at the subject discussion entitled "Parametric Modelling"
I am looking for the same thing but it is very complex. Eg. if you want to lengthen a leg you automatically adjust stature, which then changes leg length etc.
It seems to require a complicated iterative procedure.
I have yet to achieve what I want but I suspect you will need a non-linear optimisation scheme to, for example, set a target height with a known lower leg length and known torso length both held constant and everything else adjusted to "average".
