Combat boots
Combat boots
Postby learning » Thu Jan 01, 2015 7:59 pm
I've made an attempt to adapt a CC0 model of combat boots from blenderswap http://www.blendswap.com/blends/view/15722 to MH. After a lot of frustration and rather amateurish mesh editing by pushing and pulling vetices and faces, I've more or less created a half-decent mesh, but as for texturing, this I just can't do. Anyway, I think I'll share what I did, maybe someone would find it useful in current state, or maybe someone could take it over and make it better…
http://www.mediafire.com/download/kk41l ... atboots.7z
http://www.mediafire.com/download/hkzb7 ... mat4.blend
learning
Re: Combat boots
Postby Manuel » Sat Jan 03, 2015 9:59 am
Thank you.
It's a nice idea indeed, to collect all CC0 models from Blendswap and transform them in MH assets.
PS: About frustration etc... if we have enough resources, we will work on a new version of MakeClothes much more easy to use.
Re: Combat boots
Postby wizardious » Sat Jan 03, 2015 10:11 pm
Looks Good, I changed the lace from red to black though.
wizardious
Re: Combat boots
Postby duststorm » Sat Jan 03, 2015 10:56 pm
That's cool :)
I had a similar idea some time ago, when I used a blendswap model to create a piece of clothing for MH A7.
The Blendswap model was CC-BY though, so the original author credit had to be kept in all derived works.
The model and textures had a bit of a cartoonish look, though.
Shaolin costume for A7
Re: Combat boots
Postby learning » Sun Jan 04, 2015 12:42 pm
Yeah, there're probably a million ways to texture combat boots, they come in a ton of colors and materials, not just the laces, everything. It's just that I can't into texturing, so I used the texture map that was included into original model, with a lot of info lost while making the mesh into single-material single-UV-layer etc.
learning
Re: Combat boots
Postby Fordem1946 » Thu Aug 04, 2016 7:10 am
learning wrote:I've made an attempt to adapt a CC0 model of cheap tactical boots from blenderswap http://www.blendswap.com/blends/view/15722 to MH. After a lot of frustration and rather amateurish mesh editing by pushing and pulling vetices and faces, I've more or less created a half-decent mesh, but as for texturing, this I just can't do. Anyway, I think I'll share what I did, maybe someone would find it useful in current state, or maybe someone could take it over and make it better…
It is really nice keep it up
Fordem1946
Re: Combat boots
Postby MargaretToigo » Thu Feb 16, 2017 8:11 pm
I textured those combat boots with four materials in Cycles; red velvet diffuse on the laces, a diffuse and glossy mix on the lace hooks, a UV mapped tiled leather texture on the boots (diffuse, spec, and normal maps), and a simple black diffuse on the soles.
MakeClothes only does Blender internal. The MHX2 importer will convert MakeHuman materials to Cycles, but the node setup is almost always off and must be edited to get the normals and specularity to look right.
Here's what they look like...
rendered with 128 samples
MargaretToigo
