Sliders by the numbers
PostPosted: Fri Oct 10, 2014 12:45 pm
by Aedonix
In the initial modeling tab where you can set things such as age, height, weight etc, it would be useful to also include text entry boxes to set the various numbers (For example, I could manually type in the age of 27 and a height of 6' 2")
Also on that topic, could you make the display of measurements in feet and inches (or meters and centimeters) instead of just inches.
Re: Sliders by the numbers
PostPosted: Sun Oct 12, 2014 8:32 am
by duststorm
Aedonix wrote:In the initial modeling tab where you can set things such as age, height, weight etc, it would be useful to also include text entry boxes to set the various numbers (For example, I could manually type in the age of 27 and a height of 6' 2")
Indeed this has been requested quite a few times before. There's already a ticket for it pending here http://bugtracker.makehuman.org/issues/530
Aedonix wrote:Also on that topic, could you make the display of measurements in feet and inches (or meters and centimeters) instead of just inches.
You can, just go to Settings and change units to imperial.
PostPosted: Sun Oct 12, 2014 10:46 am
by Aedonix
You can, just go to Settings and change units to imperial.[/quote]
Yes. i know ans this displays in inches only... surely it would not be too hard to include the conversion
PostPosted: Sun Oct 12, 2014 10:38 pm
by duststorm
You can create a ticket for it on the tracker (http://bugtracker.makehuman.org).
PostPosted: Mon Oct 13, 2014 1:01 pm
by Manuel
