MakeHuman and OpenSim
Re: MakeHuman and OpenSim
Postby Déesse » Tue Nov 04, 2014 7:16 pm
Well, the eyes move properly in the mouth corners :lol:
Déesse
Postby Déesse » Tue Nov 11, 2014 7:15 pm
More progress:
Using the transfertool by Avastar - 2 clicks and everything works, everything at the right place :D :P :)
Déesse
Postby Miltades » Tue Dec 23, 2014 12:55 pm
Hi Deesee,
I was wondering if you could let me know which avastar update has the make human model installed? also does the avastar page have any information about the make human model?
Can you also please provide some detailed instructions on how to select the makehuman model in blender using avastar and how to ring/weight transfer.
Thank you!
Miltades
Postby sexy_muscle1977 » Fri Jan 09, 2015 8:53 pm
I just created a bodybuilder, used the SL rig, and attempted uploading to sim on a stick. The prim parts came out the size of a Mac truck. They did not resize when worn. This may be due to my current PC having limited ram.
sexy_muscle1977
Postby Supervan3 » Wed Jun 10, 2015 4:25 pm
Is the Make Human Island that's on a Sim-on-a-Stick available as an .OAR file at all for installation into a standalone instance of regular OpenSimulator? If it was available, (and it's relatively trivial to create an .OAR archive file through issuing the command
save oar <filename>.oar
which will then place the ,OAR archive file in the bin folder of SoAS, which can then be exported and shared as widely as the SoAS download - and crucially makes it available to Linux users, (also Mac).
Running a standalone instance of OpenSim is quite easy, and whilst it doesn't have the portability of SoAS, it does have the advantage of being cross-platform, which SoAS isn't.
Full documentation can be found on the main OpenSimulator website
www.opensimulator.org
Supervan3
Postby Déesse » Fri Jun 12, 2015 8:24 am
Hello Supervan3 and welcome!
"MakeHuman Island" was meant to help the developers to test and compare the rigs. I'm not sure if it is useful for the moment, because the OpenSim skeleton is working now. But if there is any interest I"ll make an update of MakeHuman Island with the latest versions of OpenSim and viewer and the new MakeHuman avatars. No problem with an .oar-file!
Déesse
