Including Rig presets in MHM Files
Postby Artist » Thu Jun 05, 2014 12:29 am
I have noticed that the Rig presets selection in the Pose/Animate tab is not saved in mhm files. It would convenient if it were. There are times I need to load the file, tweak it, and export it. When I do this I must return to this tab to select the rig with every mhm load, and it is easy to forget to do this.
The MakeHuman version I have noticed this in is 1.0.1.
Artist
Re: Including Rig presets in MHM Files
Postby duststorm » Fri Jun 06, 2014 11:07 pm
Artist wrote:I have noticed that the Rig presets selection in the Pose/Animate tab is not saved in mhm files.
It is, or it should be. I believe there is only a tiny issue that the item is not highlighted correctly, but it is there.
