IRC #makehuman wrote:[19:58:13] <Duststorm> measures are modifiers as well
[19:58:28] <Duststorm> take a look at the 0_modeling_...measurement plugin
[20:00:27] <Duststorm> see displayToData() function
[20:00:37] <Duststorm> there is no way to directly apply a numerical value
[20:00:44] <Duststorm> you need to do it by trial and error
[20:01:02] <Duststorm> apply modifier at certain amount, measure the mesh, try again
[20:02:12] <piccir> yes I was studying that and the way it works is to modify the vertex of the body part until that measure is reached, I was just looking for a high level function, as you load a mhm file
[20:03:05] <Duststorm> nothing like that is implemented
[20:03:17] <Duststorm> because we have an artistic approach
[20:03:24] <Duststorm> not a mathematical model
[20:04:51] <Duststorm> you could probably speed it up by building a search matrix of metadata (precalculated measurements) over the target space (all target combinations)
[20:05:37] <Duststorm> but you would probably soon notice that it isnt a 1-1 mapping
[20:05:47] <Duststorm> and that for many input domains there are multiple outputs
[20:06:14] <Duststorm> eg torso circumference of a thinner male == that of a heavier woman
[20:06:26] <Duststorm> and there would be many such clashes
[20:10:01] <piccir> I've already noticed that if you set the macro, the measures are pretty realistic, is just that sometimes I want to cover more subject the i need to put some measures, the measure plugin I think work well is just that the setting the micro measures is different than the macro.....
[20:11:11] <piccir> clearly if I use the -1 to 1 values as absolute I'm screwed
[20:13:05] <Duststorm> I have never really formally looked at the ranges covered
[20:13:32] <Duststorm> I know that the measure targets are simple targets
[20:13:37] <Duststorm> they dont depend on macro targets
[20:13:57] <Duststorm> so they always add or deduct the same measure units from your model
[20:14:09] <Duststorm> irrelevant what the macro is set to
[20:14:15] <Duststorm> so that simplifies things a lot
[20:14:58] <Duststorm> so if you record the measures of the macro combinations
[20:15:15] <Duststorm> and calculate the offsets of measurment targets
[20:15:31] <Duststorm> then you know what domain you can model in
[20:16:06] <piccir> That is nice! (I was just asking that)
[20:18:29] <piccir> Have you thought about the opposite process?? From a overall body decompose it in many targets?
[20:25:41] <piccir> At this point can be useful a plugin that given real measures in cm can build the subject with that measures
[20:29:27] <Duststorm> its not enough
[20:29:33] <Duststorm> as I said before
[20:29:46] <Duststorm> but you would probably soon notice that it isnt a 1-1 mapping
[20:29:52] <Duststorm> and that for many input domains there are multiple outputs
[20:29:59] <Duststorm> eg torso circumference of a thinner male == that of a heavier woman
[20:30:33] <Duststorm> you could create your own set of targets
[20:30:38] <Duststorm> eg using maketarget
[20:31:03] <Duststorm> per body part, directly on the basemesh that 1-1 map to your measurements
[20:31:19] <Duststorm> but you will probably be creating very bland and generderless characters
[20:35:01] <Duststorm> only building a character with as input measures will probably result in a character as bland as:
http://3.bp.blogspot.com/_pFGwpjnZD-g/S ... 100038.JPG[20:35:11] <Duststorm> (but full body of course)
[20:35:37] <Duststorm> and then still, you'd have to use very fine measurements as input
[20:36:00] <Duststorm> (to be able to tell if the user wants a male or female, for example)
[20:36:27] <Duststorm> breast circumference wouldnt suffice of course
[20:37:11] <piccir> Yes that could happen, but it depend the decomposition that you're using for the parameters
[20:38:00] <piccir> My question is more like: how to use all the existing targets with a different parametrization
[20:39:38] <Duststorm> build your own index
[20:39:42] <Duststorm> as I already told you
[20:39:56] <Duststorm> apply targets, measure, store, repeat
[20:40:19] <piccir> yep that the way to go
[20:40:19] <Duststorm> then you can input your desired measures in your search matrix (index)
[20:40:31] <Duststorm> and it will return the matching target combinations
[20:40:57] <Duststorm> mh targets are linearly applied
[20:41:10] <Duststorm> so you only need to calculate the extremes (applied with weight 1)
[20:41:19] <Duststorm> and 0
[20:41:22] <Duststorm> or -1
[20:41:58] <Duststorm> and then its solving a very large linear system equation
[20:42:22] <Duststorm> but I warn you, its not going to be deterministic
[20:42:58] <Duststorm> one combination of measurements can have lots of different target combinations
[20:43:31] <Duststorm> you could analyse your search matrix, and either 1) determine what extra inputs you need to make the searches deterministic
[20:44:14] <Duststorm> 2) drop all targets that cause conflicts so you are using a more limited set
[20:44:22] <piccir> if you put the problem in that way is hard to have one solution: it's what is called an ill posed problem...
[20:44:27] <Duststorm> 2 will again result in the dress doll effect
[20:44:35] <Duststorm> less variability
[20:46:29] <piccir> I think it can be treated as a machine learning problem too......
[20:47:49] <Duststorm> yes
[20:48:07] <Duststorm> but as I said, you will have to deal with the conflicts
[20:50:29] <piccir> yes it's not an easy job
[20:51:45] <piccir> Thank you for the explanation, very helpful
... (some other related chat)
[17:27:39] <Duststorm> the only way to do this in a manageable way is probably introduce some n x n matrix with weight, height, ... metrics precalculated
[17:27:49] <Duststorm> in which it can perform lookups
[17:28:06] <Duststorm> if you store all extremes of all macro targets that matter
[17:28:33] <Duststorm> its pretty fast to calculate the values using linear interpolation
[17:28:40] <Duststorm> the question is, is this worth the effort?
[17:28:49] <Duststorm> this is a considerable task
[17:29:10] <Duststorm> it might be worth it if this system will be useful for the measure plugin too
[17:29:17] <Duststorm> to work the other way around
[17:29:24] <Duststorm> from metrics to targets
[17:29:56] <Duststorm> but as I tried to explain marco, this is a linear system equation that is over-specified
[17:30:01] <Duststorm> with many possible solutions
[17:30:19] <Duststorm> metrics -> target combinations, I mean
[17:30:30] <Duststorm> target combinations -> metric is deterministic
