MakeHuman 1.0 pre-alpha not running on ubuntu 8.10 64bit
Posted: Mon Mar 02, 2009 1:03 pm
Hi, I`ve been trying to run MakeHuman 1.0 pre-alpha. I`ve downloaded zip archive from this link: http://sourceforge.net/project/showfiles.php?group_id=150931&package_id=211091 (yes, I know it`s i386 architecture only). Is there a way to run this on ubuntu 8.10 64 bit or do I have to wait for 64 bit package (will there be any soon?) ?
When I ran makehuman in terminal, it gave me that I need libpython2.5.so.1.0. I`ve found this workaround: http://www.mail-archive.com/ubuntu-bugs@lists.ubuntu.com/msg1284576.html
Now I get this when I try to run makehuman:
- Code: Select all
krzysiek@quad:~/linux/pakiety/MakeHuman/makehuman1-0-0_prealpha$ ./makehuman
File "<string>", line 1, in <module>
File "main.py", line 50, in <module>
import module3d
File "./mh_core/module3d.py", line 38, in <module>
import aljabr
File "./mh_core/aljabr.py", line 25, in <module>
import math
ImportError: /usr/lib/python2.5/lib-dynload/math.so: wrong ELF class: ELFCLASS64
Error in sys.excepthook:
File "/usr/lib/python2.5/site-packages/apport_python_hook.py", line 38, in apport_excepthook
from apport.packaging_impl import impl as packaging
File "/usr/lib/python2.5/site-packages/apport/__init__.py", line 1, in <module>
from apport.report import Report
File "/usr/lib/python2.5/site-packages/apport/report.py", line 14, in <module>
import subprocess, tempfile, os.path, urllib, re, pwd, grp, os, sys
File "/usr/lib/python2.5/subprocess.py", line 401, in <module>
import select
ImportError: /usr/lib/python2.5/lib-dynload/select.so: wrong ELF class: ELFCLASS64
Original exception was:
import module3d
import aljabr
import math
Could not run main Python script
