I found some errors in the generation of the scripts in the "render" directory:
1.
ERROR: Cannot open file "C:Documents and SettingsUSERDoc...Basezeyelashes.rib"
In the file out_render.rib I replaced the path syntax:
- Code: Select all
ReadArchive "C:\Documents and Settings\USER\..."
whith:
- Code: Select all
ReadArchive "C:\\Documents and Settings\\USER\\...b"
(double backslashes instead of single ones)
2.
ERROR: Cannot open file "C:\Documents and Settings\USER\Documenti\makehuman\rendering\Basecornea.rib"
The generated file si actually called Basezcornea.rib.
I had to manually rename it from Basezcornea.rib to Basecornea.rib.
3.
ERROR: Cannot open file "...eyelashes2_color.tx"
The file generated by the software is called eyelashes_color.tx.
In the file out_render.rib I replaced the string:
- Code: Select all
Surface "alphafur" "string texturename" "eyelashes2_color.tx"
with:
- Code: Select all
Surface "alphafur" "string texturename" "eyelashes_color.tx"
Now is it possible to render without errors:
- Code: Select all
aqsis.exe path\to\out_render.rib
obtaining the correct image and the following (clean) output:
- Code: Select all
Timings at 17:53:05 Wednesday, February 04, 2009
Frame took 17.10 seconds (called 1 time)
Dicing took 8.93 seconds (called 14,137 times)
Surface shading took 1.53 seconds (called 14,137 times)
Render MPGs took 1.33 seconds (called 32,148 times)
Prepare bucket took 1.28 seconds (called 1,900 times)
Post Surface took 0.87 seconds (called 16,143 times)
Parse took 311.03 milli secs (called 1 time)
Project points took 288.71 milli secs (called 14,137 times)
Filter took 284.01 milli secs (called 1,900 times)
Bust grids took 264.96 milli secs (called 14,137 times)
Dicable check took 263.13 milli secs (called 16,111 times)
Display bucket took 177.18 milli secs (called 1,900 times)
Splits took 120.98 milli secs (called 1,974 times)
Occlusion culling initialisation took 80.98 milli secs (called 240 times)
Occlusion culling surfaces took 43.56 milli secs (called 16,584 times)
Combine took 19.73 milli secs (called 240 times)
Timings at 17:53:31 Wednesday, February 04, 2009
Frame took 43.29 seconds (called 2 times)
Dicing took 19.46 seconds (called 28,498 times)
Surface shading took 5.90 seconds (called 28,498 times)
Displacement took 3.47 seconds (called 13,881 times)
Render MPGs took 3.44 seconds (called 64,771 times)
Prepare bucket took 2.55 seconds (called 3,800 times)
Post Surface took 1.85 seconds (called 32,505 times)
Parse took 0.64 seconds (called 2 times)
Project points took 0.61 seconds (called 28,498 times)
Filter took 0.61 seconds (called 3,800 times)
Bust grids took 0.58 seconds (called 28,498 times)
Dicable check took 0.57 seconds (called 32,473 times)
Display bucket took 355.24 milli secs (called 3,800 times)
Splits took 257.80 milli secs (called 3,975 times)
Occlusion culling initialisation took 238.18 milli secs (called 525 times)
Occlusion culling surfaces took 91.67 milli secs (called 33,174 times)
Combine took 46.66 milli secs (called 525 times)
Occlusion culling took 15.96 milli secs (called 27,762 times)
Timings at 17:53:36 Wednesday, February 04, 2009
Frame took 47.63 seconds (called 3 times)
Dicing took 21.51 seconds (called 38,090 times)
Surface shading took 5.97 seconds (called 34,500 times)
Render MPGs took 3.59 seconds (called 81,291 times)
Prepare bucket took 2.67 seconds (called 4,275 times)
Post Surface took 2.37 seconds (called 42,556 times)
Parse took 1.02 seconds (called 3 times)
Dicable check took 0.72 seconds (called 42,516 times)
Project points took 0.70 seconds (called 34,500 times)
Filter took 0.66 seconds (called 4,275 times)
Bust grids took 0.63 seconds (called 34,500 times)
Display bucket took 391.44 milli secs (called 4,275 times)
Splits took 333.98 milli secs (called 4,426 times)
Occlusion culling initialisation took 250.17 milli secs (called 598 times)
Occlusion culling surfaces took 116.46 milli secs (called 43,364 times)
Combine took 49.63 milli secs (called 598 times)
Backface culling took 30.26 milli secs (called 9,592 times)
Timings at 17:53:50 Wednesday, February 04, 2009
Frame took 61.72 seconds (called 4 times)
Dicing took 27.62 seconds (called 49,094 times)
Surface shading took 7.68 seconds (called 41,604 times)
Displacement took 5.64 seconds (called 24,501 times)
Render MPGs took 4.31 seconds (called 102,211 times)
Prepare bucket took 3.13 seconds (called 6,175 times)
Post Surface took 3.04 seconds (called 54,472 times)
Parse took 1.34 seconds (called 4 times)
Dicable check took 0.94 seconds (called 54,432 times)
Project points took 0.85 seconds (called 41,604 times)
Filter took 0.82 seconds (called 6,175 times)
Bust grids took 0.75 seconds (called 41,604 times)
Display bucket took 0.54 seconds (called 6,175 times)
Splits took 429.22 milli secs (called 5,338 times)
Occlusion culling initialisation took 288.11 milli secs (called 882 times)
Occlusion culling surfaces took 150.73 milli secs (called 55,662 times)
Backface culling took 74.99 milli secs (called 20,596 times)
Combine took 61.37 milli secs (called 882 times)
Timings at 17:53:53 Wednesday, February 04, 2009
Frame took 63.74 seconds (called 5 times)
Prepare bucket took 4.46 seconds (called 8,075 times)
Render MPGs took 4.31 seconds (called 104,111 times)
Post Surface took 3.05 seconds (called 54,477 times)
Parse took 1.68 seconds (called 5 times)
Filter took 0.88 seconds (called 8,075 times)
Display bucket took 0.71 seconds (called 8,075 times)
Timings at 17:55:43 Wednesday, February 04, 2009
Frame took 173.47 seconds (called 6 times)
Surface shading took 78.08 seconds (called 49,796 times)
Dicing took 30.21 seconds (called 57,286 times)
Prepare bucket took 12.59 seconds (called 9,975 times)
Render MPGs took 11.27 seconds (called 130,587 times)
Filter took 3.42 seconds (called 9,975 times)
Post Surface took 3.30 seconds (called 70,861 times)
Bust grids took 2.72 seconds (called 49,796 times)
Occlusion culling initialisation took 2.55 seconds (called 2,782 times)
Combine took 2.52 seconds (called 2,782 times)
Display bucket took 2.03 seconds (called 9,975 times)
Parse took 1.68 seconds (called 6 times)
Project points took 1.61 seconds (called 49,796 times)
Dicable check took 1.09 seconds (called 70,816 times)
Splits took 0.73 seconds (called 13,530 times)
Texture took 0.51 seconds (called 5 times)
Occlusion culling surfaces took 207.62 milli secs (called 72,046 times)
Occlusion culling took 27.21 milli secs (called 44,146 times)
Hope it helps.
MarcoA
