Rendering does not produce an image
Hello all this is my first post. Very impressed by makehuman and thank you very much for developing such a cool program. I do, however, have a problem when rendering. I'm running your RC on Vista 64 Ultimate, and Aqsis version 1.4.2. Both installed in "C:\Program Files (x86)". When I hit the "rendering preview" button a blank (no image just a black screen) is rendered. The ouput from the console is included below:
aqsis version 1.4.2 (revision 2714)
compiled Jan 21 2009 21:19:03
02/01/2009 17:14:06 INFO: Reading system config "c:\program files (x86)\aqsis\bi
n\aqsisrc"
02/01/2009 17:14:06 INFO: Environment variable HOME not set (skipping user confi
g).
02/01/2009 17:14:06 INFO: Could not open project config (.aqsisrc)
02/01/2009 17:14:06 INFO: AQSIS_SHADER_PATH not set
02/01/2009 17:14:06 INFO: AQSIS_ARCHIVE_PATH not set
02/01/2009 17:14:06 INFO: AQSIS_TEXTURE_PATH not set
02/01/2009 17:14:06 INFO: AQSIS_DISPLAY_PATH not set
02/01/2009 17:14:06 INFO: AQSIS_PROCEDURAL_PATH not set
02/01/2009 17:14:06 INFO: Setting up default display: Display "ri.pic" "file" "r
gba"
02/01/2009 17:14:06 INFO: Applying search paths provided at the command line
02/01/2009 17:14:06 INFO: DSO lib path set to "C:/Program Files (x86)/Aqsis/shad
ers:.:/../SimbiontRM:/..:"
02/01/2009 17:14:06 INFO: Loading shader "pointlight" from file "C:/Program File
s (x86)/Aqsis/shaders\pointlight.slx"
02/01/2009 17:14:06 INFO: Loading shader "ambientlight" from file "C:/Program Fi
les (x86)/Aqsis/shaders\ambientlight.slx"
02/01/2009 17:14:06 INFO: Loading shader "matte" from file "C:/Program Files (x8
6)/Aqsis/shaders\matte.slx"
enderingBaseHEAD.rib"RROR: Cannot open file "C:UsersdamiriDocumentsmakehuman
enderingBaseBODY.rib"RROR: Cannot open file "C:UsersdamiriDocumentsmakehuman
02/01/2009 17:14:06 INFO: Image settings:
02/01/2009 17:14:06 INFO: Resolution: 800 600
02/01/2009 17:14:06 INFO: PixelAspectRatio: 1
02/01/2009 17:14:06 INFO: Exposure:
02/01/2009 17:14:06 INFO: Gain: 1
02/01/2009 17:14:06 INFO: Gamma: 1
02/01/2009 17:14:06 INFO: Shading:
02/01/2009 17:14:06 INFO: Bucket size: [ 16 16]
02/01/2009 17:14:06 INFO: Gridsize: 256
02/01/2009 17:14:06 INFO: Anti-aliasing settings:
02/01/2009 17:14:06 INFO: PixelSamples: 2 2
02/01/2009 17:14:06 INFO: PixelFilter: "gaussian" 2 2
02/01/2009 17:14:06 INFO: Loading plugin "C:/Program Files (x86)/Aqsis/bin\piqsl
display.dll"
02/01/2009 17:14:07 INFO: Will try to start a framebuffer
02/01/2009 17:14:07 INFO: Starting the framebuffer
02/01/2009 17:14:07 INFO: Loading plugin "C:/Program Files (x86)/Aqsis/bin\displ
ay.dll"
enderingpreview.tif: Cannot open.akehuman
Many thanks to anyone that can help me.
n\aqsisrc"
g).
gba"
display.dll"
ay.dll"
