Rendering does not produce an image
Postby damiri » Mon Feb 02, 2009 1:24 am
Hello all this is my first post. Very impressed by makehuman and thank you very much for developing such a cool program. I do, however, have a problem when rendering. I'm running your RC on Vista 64 Ultimate, and Aqsis version 1.4.2. Both installed in "C:\Program Files (x86)". When I hit the "rendering preview" button a blank (no image just a black screen) is rendered. The ouput from the console is included below:
aqsis version 1.4.2 (revision 2714)
compiled Jan 21 2009 21:19:03
02/01/2009 17:14:06 INFO: Reading system config "c:\program files (x86)\aqsis\bi
n\aqsisrc"
02/01/2009 17:14:06 INFO: Environment variable HOME not set (skipping user confi
g).
02/01/2009 17:14:06 INFO: Could not open project config (.aqsisrc)
02/01/2009 17:14:06 INFO: AQSIS_SHADER_PATH not set
02/01/2009 17:14:06 INFO: AQSIS_ARCHIVE_PATH not set
02/01/2009 17:14:06 INFO: AQSIS_TEXTURE_PATH not set
02/01/2009 17:14:06 INFO: AQSIS_DISPLAY_PATH not set
02/01/2009 17:14:06 INFO: AQSIS_PROCEDURAL_PATH not set
02/01/2009 17:14:06 INFO: Setting up default display: Display "ri.pic" "file" "r
gba"
02/01/2009 17:14:06 INFO: Applying search paths provided at the command line
02/01/2009 17:14:06 INFO: DSO lib path set to "C:/Program Files (x86)/Aqsis/shad
ers:.:/../SimbiontRM:/..:"
02/01/2009 17:14:06 INFO: Loading shader "pointlight" from file "C:/Program File
s (x86)/Aqsis/shaders\pointlight.slx"
02/01/2009 17:14:06 INFO: Loading shader "ambientlight" from file "C:/Program Fi
les (x86)/Aqsis/shaders\ambientlight.slx"
02/01/2009 17:14:06 INFO: Loading shader "matte" from file "C:/Program Files (x8
6)/Aqsis/shaders\matte.slx"
enderingBaseHEAD.rib"RROR: Cannot open file "C:UsersdamiriDocumentsmakehuman
enderingBaseBODY.rib"RROR: Cannot open file "C:UsersdamiriDocumentsmakehuman
02/01/2009 17:14:06 INFO: Image settings:
02/01/2009 17:14:06 INFO: Resolution: 800 600
02/01/2009 17:14:06 INFO: PixelAspectRatio: 1
02/01/2009 17:14:06 INFO: Exposure:
02/01/2009 17:14:06 INFO: Gain: 1
02/01/2009 17:14:06 INFO: Gamma: 1
02/01/2009 17:14:06 INFO: Shading:
02/01/2009 17:14:06 INFO: Bucket size: [ 16 16]
02/01/2009 17:14:06 INFO: Gridsize: 256
02/01/2009 17:14:06 INFO: Anti-aliasing settings:
02/01/2009 17:14:06 INFO: PixelSamples: 2 2
02/01/2009 17:14:06 INFO: PixelFilter: "gaussian" 2 2
02/01/2009 17:14:06 INFO: Loading plugin "C:/Program Files (x86)/Aqsis/bin\piqsl
display.dll"
02/01/2009 17:14:07 INFO: Will try to start a framebuffer
02/01/2009 17:14:07 INFO: Starting the framebuffer
02/01/2009 17:14:07 INFO: Loading plugin "C:/Program Files (x86)/Aqsis/bin\displ
ay.dll"
enderingpreview.tif: Cannot open.akehuman
Many thanks to anyone that can help me.
damiri
Re: Rendering does not produce an image
Postby Jep » Mon Feb 02, 2009 4:24 pm
Have you set the path for Aqsis from MH's command line?
Please read the quickstart.
Jep
Postby damiri » Tue Feb 03, 2009 5:09 am
Yes. I have done:
aqs c:\program files (x86)\aqsis
and the path is set successfully (at least that's what the console says). It is definitely finding the executable because it launches piqsl.exe. The problem is that the image that is rendered is simply a blank (completely black) image.
damiri
Postby Jep » Tue Feb 03, 2009 9:59 am
damiri wrote:aqs c:\program files (x86)\aqsis
Maybe the problem lies in the spaces in the path name. Preview works fine for me. You may try installing aqsis in some folder path with a 8.3 format.
Jep
Postby ElAnimal » Sat Jun 13, 2009 10:51 pm
I have this exact same problem on Vista 32. Did the last offered solution work? DOes anybody have advice on this?
My console output is exaclty the same, including the two strange errors.
ElAnimal
Postby ElAnimal » Sat Jun 13, 2009 11:04 pm
I just tried re-installing Aqsis in another folder and still no luck. Makehuman acts like it communicates with Aqsis in the dialog box, but the render is blank.
ElAnimal
