Installing on my Ubuntu machine
Postby matthewbaynham » Wed Feb 26, 2025 4:32 pm
This website here https://launchpad.net/~makehuman-official/+archive/ubuntu/makehuman-community
...gives the instruction to do...
sudo add-apt-repository ppa:makehuman-official/makehuman-community
sudo apt-get update
sudo apt-get install makehuman-community
But I get the message
E: Unable to locate package makehuman-community
This came after the message...
Error: The repository 'https://ppa.launchpadcontent.net/makehuman-official/makehuman-community/ubuntu oracular Release' does not have a Release file.
Notice: Updating from such a repository can't be done securely, and is therefore disabled by default.
Notice: See apt-secure(8) manpage for repository creation and user configuration details.
The full command stuff is...
matthew@matthew-big-tower:/etc/samba$ sudo add-apt-repository ppa:makehuman-official/makehuman-community
[sudo] password for matthew:
Repository: 'Types: deb
URIs: https://ppa.launchpadcontent.net/makehuman-official/makehuman-community/ubuntu/
Suites: oracular
Components: main
Description:
This PPA contains builds of MakeHuman 1.2.x, bundled with community addons (such as MHX). The MakeHuman Community 12x series is a different code branch than the MakeHuman 11x code. The source for MakeHuman and most of the addons can be found at https://github.com/makehumancommunity.
Packages from this PPA should be possible to install and run alongside packages from the makehuman-11x PPA.
To enable the PPA and then install MakeHuman, run:
sudo apt-get update
On ubuntu this will install all plugins as they are "Recommends" in the packages. If you have switched off "Recommends", or if you are using Mint, you might also want to do:
sudo apt-get install makehuman-community-plugins-socket makehuman-community-plugins-assetdownloader mhx2-makehuman-exchange
This will install some plugins you are likely to want.
For more information, see http://www.makehumancommunity.org
This PPA also contains optional packages. The "makehuman-blendertools" package installs blender integration. The "makehuman-targets-dev", "makehuman-clothes-dev", "makehuman-hair-dev" and "makehuman-bodyparts-dev" contain raw targets and obj files for targets, clothes, hair and body parts respectively. Most people do not need the "*-dev " packages, but if you plan to develop new targets, the "makehuman-targets-dev" might make sense.
If you have questions, ask them on the MakeHuman forum: http://www.makehumancommunity.org/forum
If you need to make a bug report, post it on the MakeHuman bug tracker: http://bugtracker.makehumancommunity.org
More info: https://launchpad.net/~makehuman-official/+archive/ubuntu/makehuman-community
Adding repository.
Press [ENTER] to continue or Ctrl-c to cancel.
Hit:1 http://de.archive.ubuntu.com/ubuntu oracular InRelease
Get:2 http://de.archive.ubuntu.com/ubuntu oracular-updates InRelease [126 kB]
Hit:3 https://nvidia.github.io/libnvidia-container/stable/deb/amd64  InRelease
Get:4 http://security.ubuntu.com/ubuntu oracular-security InRelease [126 kB]
Ign:5 https://ppa.launchpadcontent.net/makehuman-official/makehuman-community/ubuntu oracular InRelease
Hit:6 https://nvidia.github.io/libnvidia-container/experimental/deb/amd64  InRelease
Err:7 https://ppa.launchpadcontent.net/makehuman-official/makehuman-community/ubuntu oracular Release
  404  Not Found [IP: 2620:2d:4000:1::81 443]
Get:8 http://de.archive.ubuntu.com/ubuntu oracular-backports InRelease [126 kB]
Get:9 http://de.archive.ubuntu.com/ubuntu oracular-updates/main amd64 Packages [299 kB]
Get:10 http://de.archive.ubuntu.com/ubuntu oracular-updates/main amd64 Components [35.3 kB]
Get:11 http://de.archive.ubuntu.com/ubuntu oracular-updates/restricted amd64 Components [216 B]
Get:12 http://de.archive.ubuntu.com/ubuntu oracular-updates/universe amd64 Packages [181 kB]
Get:13 http://de.archive.ubuntu.com/ubuntu oracular-updates/universe amd64 Components [55.1 kB]
Get:14 http://de.archive.ubuntu.com/ubuntu oracular-updates/multiverse amd64 Components [216 B]
Get:15 http://de.archive.ubuntu.com/ubuntu oracular-backports/main amd64 Components [212 B]
Get:16 http://de.archive.ubuntu.com/ubuntu oracular-backports/restricted amd64 Components [216 B]
Get:17 http://de.archive.ubuntu.com/ubuntu oracular-backports/universe amd64 Components [9,696 B]
Get:18 http://de.archive.ubuntu.com/ubuntu oracular-backports/multiverse amd64 Components [216 B]
Get:19 http://security.ubuntu.com/ubuntu oracular-security/main amd64 Packages [223 kB]
Get:20 http://security.ubuntu.com/ubuntu oracular-security/main Translation-en [57.8 kB]
Get:21 http://security.ubuntu.com/ubuntu oracular-security/main amd64 Components [8,992 B]
Get:22 http://security.ubuntu.com/ubuntu oracular-security/restricted amd64 Components [212 B]
Get:23 http://security.ubuntu.com/ubuntu oracular-security/universe amd64 Packages [137 kB]
Get:24 http://security.ubuntu.com/ubuntu oracular-security/universe Translation-en [42.4 kB]
Get:25 http://security.ubuntu.com/ubuntu oracular-security/universe amd64 Components [5,552 B]
Get:26 http://security.ubuntu.com/ubuntu oracular-security/multiverse amd64 Components [212 B]
Reading package lists... Done
E: The repository 'https://ppa.launchpadcontent.net/makehuman-official/makehuman-community/ubuntu oracular Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
matthew@matthew-big-tower:/etc/samba$ sudo apt update
Hit:1 http://security.ubuntu.com/ubuntu oracular-security InRelease
Hit:2 http://de.archive.ubuntu.com/ubuntu oracular InRelease
Hit:4 http://de.archive.ubuntu.com/ubuntu oracular-updates InRelease
Hit:5 https://nvidia.github.io/libnvidia-container/experimental/deb/amd64  InRelease
Hit:6 http://de.archive.ubuntu.com/ubuntu oracular-backports InRelease
Ign:7 https://ppa.launchpadcontent.net/makehuman-official/makehuman-community/ubuntu oracular InRelease
Err:8 https://ppa.launchpadcontent.net/makehuman-official/makehuman-community/ubuntu oracular Release
matthew@matthew-big-tower:/etc/samba$ sudo apt upgrade
Upgrading:
  binutils  binutils-common  binutils-x86-64-linux-gnu  libbinutils  libctf-nobfd0  libctf0  libgprofng0  libsframe1
Not upgrading yet due to phasing:
  initramfs-tools  initramfs-tools-bin  initramfs-tools-core
Summary:
  Upgrading: 8, Installing: 0, Removing: 0, Not Upgrading: 3
8 standard LTS security updates
  Download size: 4,416 kB
  Space needed: 0 B / 217 GB available
Continue? [Y/n] y
Get:1 http://security.ubuntu.com/ubuntu oracular-security/main amd64 libctf-nobfd0 amd64 2.43.1-4ubuntu1.1 [99.2 kB]
Get:2 http://security.ubuntu.com/ubuntu oracular-security/main amd64 libgprofng0 amd64 2.43.1-4ubuntu1.1 [871 kB]
Get:3 http://security.ubuntu.com/ubuntu oracular-security/main amd64 libctf0 amd64 2.43.1-4ubuntu1.1 [96.2 kB]
Get:4 http://security.ubuntu.com/ubuntu oracular-security/main amd64 binutils-x86-64-linux-gnu amd64 2.43.1-4ubuntu1.1 [2,507 kB]
Get:5 http://security.ubuntu.com/ubuntu oracular-security/main amd64 libbinutils amd64 2.43.1-4ubuntu1.1 [580 kB]
Get:6 http://security.ubuntu.com/ubuntu oracular-security/main amd64 binutils amd64 2.43.1-4ubuntu1.1 [3,206 B]
Get:7 http://security.ubuntu.com/ubuntu oracular-security/main amd64 binutils-common amd64 2.43.1-4ubuntu1.1 [244 kB]
Get:8 http://security.ubuntu.com/ubuntu oracular-security/main amd64 libsframe1 amd64 2.43.1-4ubuntu1.1 [15.2 kB]
Fetched 4,416 kB in 4s (1,219 kB/s)
(Reading database ... 233637 files and directories currently installed.)
Preparing to unpack .../0-libctf-nobfd0_2.43.1-4ubuntu1.1_amd64.deb ...
Unpacking libctf-nobfd0:amd64 (2.43.1-4ubuntu1.1) over (2.43.1-4ubuntu1) ...
Preparing to unpack .../1-libgprofng0_2.43.1-4ubuntu1.1_amd64.deb ...
Unpacking libgprofng0:amd64 (2.43.1-4ubuntu1.1) over (2.43.1-4ubuntu1) ...
Preparing to unpack .../2-libctf0_2.43.1-4ubuntu1.1_amd64.deb ...
Unpacking libctf0:amd64 (2.43.1-4ubuntu1.1) over (2.43.1-4ubuntu1) ...
Preparing to unpack .../3-binutils-x86-64-linux-gnu_2.43.1-4ubuntu1.1_amd64.deb ...
Unpacking binutils-x86-64-linux-gnu (2.43.1-4ubuntu1.1) over (2.43.1-4ubuntu1) ...
Preparing to unpack .../4-libbinutils_2.43.1-4ubuntu1.1_amd64.deb ...
Unpacking libbinutils:amd64 (2.43.1-4ubuntu1.1) over (2.43.1-4ubuntu1) ...
Preparing to unpack .../5-binutils_2.43.1-4ubuntu1.1_amd64.deb ...
Unpacking binutils (2.43.1-4ubuntu1.1) over (2.43.1-4ubuntu1) ...
Preparing to unpack .../6-binutils-common_2.43.1-4ubuntu1.1_amd64.deb ...
Unpacking binutils-common:amd64 (2.43.1-4ubuntu1.1) over (2.43.1-4ubuntu1) ...
Preparing to unpack .../7-libsframe1_2.43.1-4ubuntu1.1_amd64.deb ...
Unpacking libsframe1:amd64 (2.43.1-4ubuntu1.1) over (2.43.1-4ubuntu1) ...
Setting up binutils-common:amd64 (2.43.1-4ubuntu1.1) ...
Setting up libctf-nobfd0:amd64 (2.43.1-4ubuntu1.1) ...
Setting up libsframe1:amd64 (2.43.1-4ubuntu1.1) ...
Setting up libbinutils:amd64 (2.43.1-4ubuntu1.1) ...
Setting up libctf0:amd64 (2.43.1-4ubuntu1.1) ...
Setting up libgprofng0:amd64 (2.43.1-4ubuntu1.1) ...
Setting up binutils-x86-64-linux-gnu (2.43.1-4ubuntu1.1) ...
Setting up binutils (2.43.1-4ubuntu1.1) ...
Processing triggers for libc-bin (2.40-1ubuntu3.1) ...
Processing triggers for man-db (2.12.1-3) ...
matthew@matthew-big-tower:/etc/samba$ sudo apt autoremove
Summary:
  Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 3
Hit:2 http://de.archive.ubuntu.com/ubuntu oracular-updates InRelease
Hit:4 https://nvidia.github.io/libnvidia-container/experimental/deb/amd64  InRelease
Hit:5 http://de.archive.ubuntu.com/ubuntu oracular-backports InRelease
Ign:6 https://ppa.launchpadcontent.net/makehuman-official/makehuman-community/ubuntu oracular InRelease
Hit:8 http://security.ubuntu.com/ubuntu oracular-security InRelease
Summary:
Summary:
matthew@matthew-big-tower:/etc/samba$ sudo apt-get install makehuman-community
Building dependency tree... Done
Reading state information... Done
matthewbaynham
Users browsing this forum: No registered users and 13 guests
