MakeHuman - Makehuman won't start
Postby Simmon24 » Mon Oct 14, 2024 5:45 pm
Hey, I'm new to this forum. I've been using the program for about 2 weeks now. Not so long ago I had to reinstall the system and reinstall applications on the computer including Makehuman and for some time now this application is not able to start, even though I had no problem with it before.
I'm using a desktop computer with Windows 10 Home 22H2 – 64bit
My graphic card - AMD Radeon RX 580 2048SP[/b]
I only use a dedicated graphics card.
Other than that, my computer only "sees" a dedicated graphics card.
My version of Makehuman is 1.3.0
I installed the previous version and it also won't start
P.S - File python_out is empty.
makehuman.log
[2024-10-14 19:23:59,864] log.py->message():118 -- MESSAGE -- Initialized logging
[2024-10-14 19:23:59,872] log.py->debug():97 -- DEBUG -- VERSION: 1.2.1 alpha
[2024-10-14 19:23:59,873] log.py->debug():97 -- DEBUG -- SHORT VERSION: alpha
[2024-10-14 19:23:59,873] log.py->debug():97 -- DEBUG -- LONG VERSION: 1.3.0 alpha (master:570790ca)
[2024-10-14 19:23:59,873] log.py->debug():97 -- DEBUG -- BASEMESH VERSION: hm08
[2024-10-14 19:23:59,873] log.py->debug():97 -- DEBUG -- IS BUILT (FROZEN): No
[2024-10-14 19:23:59,873] log.py->debug():97 -- DEBUG -- IS RELEASE VERSION: Yes
[2024-10-14 19:23:59,873] log.py->debug():97 -- DEBUG -- DEFAULT ENCODING: utf-8
[2024-10-14 19:23:59,873] log.py->debug():97 -- DEBUG -- FILESYSTEM ENCODING: utf-8
[2024-10-14 19:23:59,873] log.py->debug():97 -- DEBUG -- STDOUT ENCODING: cp1250
[2024-10-14 19:23:59,874] log.py->debug():97 -- DEBUG -- LOCALE PREFERRED ENCODING: cp1250
[2024-10-14 19:23:59,874] log.py->debug():97 -- DEBUG -- WORKING DIRECTORY: C:\Program Files\makehuman-community\makehuman
[2024-10-14 19:23:59,874] log.py->debug():97 -- DEBUG -- HOME LOCATION: C:/Users/Szymon/Documents
[2024-10-14 19:23:59,874] log.py->debug():97 -- DEBUG -- PYTHON PATH: ./;./lib;./apps;./shared;./apps/gui;./core;C:\Program Files\makehuman-community\Python\python37.zip;C:\Program Files\makehuman-community\Python;C:\Program Files\makehuman-community\pkgs
[2024-10-14 19:23:59,874] log.py->debug():97 -- DEBUG -- DLL PATH: C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Users\Szymon\AppData\Local\Microsoft\WindowsApps
[2024-10-14 19:23:59,874] log.py->debug():97 -- DEBUG -- SYS.VERSION: 3.7.6 (tags/v3.7.6:43364a7ae0, Dec 19 2019, 00:42:30) [MSC v.1916 64 bit (AMD64)]
[2024-10-14 19:23:59,874] log.py->debug():97 -- DEBUG -- SYS.PLATFORM: win32
[2024-10-14 19:23:59,875] log.py->debug():97 -- DEBUG -- SYS.EXECUTABLE: C:\Program Files\makehuman-community\Python\pythonw.exe
[2024-10-14 19:23:59,875] log.py->debug():97 -- DEBUG -- PLATFORM.MACHINE: AMD64
[2024-10-14 19:23:59,875] log.py->debug():97 -- DEBUG -- PLATFORM.PROCESSOR: Intel64 Family 6 Model 63 Stepping 2, GenuineIntel
[2024-10-14 19:23:59,875] log.py->debug():97 -- DEBUG -- PLATFORM.UNAME.RELEASE: 10
[2024-10-14 19:23:59,875] log.py->debug():97 -- DEBUG -- PLATFORM.WIN32_VER: 10 10.0.19041 SP0
[2024-10-14 19:24:00,059] log.py->debug():97 -- DEBUG -- NUMPY.VERSION: 1.18.1
[2024-10-14 19:24:00,077] acceleratesupport.py-><module>():23 -- MESSAGE -- No OpenGL_accelerate module loaded: No module named 'OpenGL_accelerate'
(2.58 KiB) Downloaded 492 times
makehuman-debug.txt
SYS.PLATFORM: win32
(1.13 KiB) Downloaded 507 times
python_err.txt
Initialized logging
SYS.PLATFORM: win32
File "makehuman.py", line 621, in <module>
main()
File "makehuman.py", line 611, in main
from mhmain import MHApplication
File "./core\mhmain.py", line 44, in <module>
import mh
File "./lib\mh.py", line 50, in <module>
from qtui import Keys, Buttons, Modifiers, Application
File "./lib\qtui.py", line 45, in <module>
from PyQt5 import QtCore, QtGui, QtOpenGL, QtWidgets
ImportError: DLL load failed: Nie można odnaleźć określonego modułu.
(1.72 KiB) Downloaded 503 times
Simmon24
Re: MakeHuman - Makehuman won't start
Postby joepal » Tue Oct 22, 2024 7:30 am
It is difficult to know what happens here, but the error message indicates that a DLL file cannot be found. Why this is so is not written, not which DLL file we're talking about. It might be a driver for the graphics card or a openql or qt file which was bundled with makehuman.
My suggestion would be to remove all traces of makehuman (uninstall it, delete all directories which were installed previously) and then try to make a fresh start. If that does not work, I'd next start looking at if something is wrong with the graphics drivers.
Postby Simmon24 » Tue Oct 22, 2024 2:07 pm
joepal wrote:It is difficult to know what happens here, but the error message indicates that a DLL file cannot be found. Why this is so is not written, not which DLL file we're talking about. It might be a driver for the graphics card or a openql or qt file which was bundled with makehuman.
Thank you for the answer, but the problem seems to have solved itself, right after I installed the Steam applications,... Strange, isn't it? :shock: :?:
Simmon24
