1.3.0 linux won't open mhm from 1.2
Postby nomorecookies » Fri May 31, 2024 2:13 pm
I have switched to Linux. after successfully running MH from source, i attempted to open an mhm i had saved.
it essentially told me it cannot open 1.2 and no fallback solution is available.
  File "/var/home/me/Projects/Programs/makehuman/core/events3d.py", line 211, in callEvent
    method(event)
  File "/var/home/me/Projects/Programs/makehuman/apps/gui/guiload.py", line 109, in onFileSelected
    gui3d.app.loadHumanMHM(filename)
  File "/var/home/me/Projects/Programs/makehuman/core/mhmain.py", line 404, in loadHumanMHM
    self.selectedHuman.load(filename, True)
  File "/var/home/me/Projects/Programs/makehuman/apps/human.py", line 1553, in load
    compat.loadMHM(version, lines, _load_property, strict)
  File "/var/home/me/Projects/Programs/makehuman/apps/compat.py", line 338, in loadMHM
    loader = getMHMLoader(version_)
  File "/var/home/me/Projects/Programs/makehuman/apps/compat.py", line 330, in getMHMLoader
    raise RuntimeError("No suitable MHM backward compatibility loader found for version %s" % (version, ))
RuntimeError: No suitable MHM backward compatibility loader found for version [1, 2, 1]
nomorecookies
Re: 1.3.0 linux won't open mhm from 1.2
Postby nomorecookies » Sun Jun 02, 2024 3:45 am
Note that since the information in the file is the same between the two versions, this is a soft error, not an actual error. You can open your .mhm file in a text editor, and change the 1.2.0, or 1.2.1 at t he top to 1.3.0 and the file loads normally
nomorecookies
Postby joepal » Mon Jun 03, 2024 4:56 am
