Tech. problem : build with BCB 6 (under WindowsXP)
Postby NicoFromBelgium » Thu Aug 14, 2008 8:50 am
Hi everybody!
Firstly : I want to congratulate the project and all people who contribute, it's a really good job.
I'm trying to build the project under WinXP, BCB6.
I've the last source code (ver. 9.1)
I fixed a lot of little problem (path, include not recognised, png and zlib dependencies,...)
I've now a problem with animation.cpp
Line 94 : (first line in function void Animation::interpolate(BodySettings &prev, BodySettings &next) )
BodySettings interPoses[interpNumber]; //the error message is : Constant expression required
Any idea to fix it?
NicoFromBelgium
Re: Tech. problem : build with BCB 6 (under WindowsXP)
Postby NicoFromBelgium » Mon Aug 25, 2008 6:50 am
Bug corrected, but not as clean as i want ( i changed "interpNumber" to 1000 )
Other problem : in "utils.cpp" line 337 : Cannot convert 'char*' to 'RIB_PARAM_STRING'
RIB_PARAM_STRING editParametersString[LAST_PARAM_STRING]=
{"rendpath","${RENDERING_PATH}",parametersString_def[RENDPATH_PARAM_STRING]},
I try some things, but nothing work...
Edit : I find the problem...
#define struct my_struct{char* a;char* b;String c;} My_Struct;
My_Struct test[3]={{"123","abc","xyz"},{"456","abc","xyz"},{"789","abc","xyz"}};
it don't work because "123" is interpreted like a My_Struct, and not a char*. I try to initialise this in a function, member by member, it work, but I can't do that because i don't know when the array is use the first time (maybe before my function call).
I find other case like this (in mesh.cpp).
I'm looking after a solution. If someone find before me... :-)
NicoFromBelgium
