hair_female_medium
hair_female_medium
Postby SSFS » Thu Dec 29, 2022 12:19 pm
http://www.makehumancommunity.org/cloth ... edium.html
I can't seem to get this to work, as it it just shows as a grey/sliver helmet. I'm using the latest version of MH.
SSFS
Re: hair_female_medium
Postby joepal » Fri Dec 30, 2022 1:48 pm
That particular hair does not come with a full makehuman material. Instead the author has posted a sample node setup as the render image. From what I can see you have a RGB node there for regulating the hair color.
Postby SSFS » Thu Apr 20, 2023 3:15 pm
I was finally able to get it to work. First I had to manually edit the hair_medium.mhmat file and add the Textures and properties lines (something I've never done before), then I figured out how to enable the materials editor in the utilities tab. One problem is I can't figure out how to change the headband color, only the hair. The original illustration had it orange.
SSFS
Postby SSFS » Thu Apr 20, 2023 3:27 pm
Here's some samples of mine after I edited the file and used the materials editor.
SSFS
Postby green_tomato » Thu May 18, 2023 8:49 pm
I just made this. Try see if this material might help:
http://www.makehumancommunity.org/conte ... ium_2.html
green_tomato
Postby SSFS » Wed Jul 26, 2023 7:59 am
green_tomato wrote:I just made this. Try see if this material might help:
Hey, thanks for the upload! I'm working with it now, I'll post some images when I get more time. Maybe I'll get around to uploading my hacks to the assets, just not sure if they're ready yet.
SSFS
