MPFB - AGE
MPFB - AGE
Postby viebrix » Mon Oct 31, 2022 8:42 pm
Thanks for this great software!
In the Blender Plugin, I found a little bug. When I change the age of a model this changes the model in different ways. So e.g. the model size will decrease when the model is younger. But this only works for ages 0.19 and higher. For all values less than (age) 0.19 the model is very high/big (seems to be not any more correlated with the age) - seems something breaks on this age level of 0.18/0.19.
Hope you can understand what I mean. Sorry I'm not native speaker.
viebrix
Re: MPFB - AGE
Postby joepal » Wed Nov 02, 2022 8:23 am
I can confirm that there's an error here. Basically, the procedure crashes if there's a residual female adult component (such as breast firmness) and the age changes to baby.
I'm on it. For now I've created a bug report at https://github.com/makehumancommunity/mpfb2/issues/60
As a workaround, you can create a new human with age baby, gender male and be sure to uncheck the "add breast targets". This way you should be able to get a functional baby character to work with.
Re: MPFB - AGE
Postby viebrix » Fri Nov 04, 2022 9:19 pm
Thanks for confirmation and the workaround.
Model was set to man/boy but you are right - initial I copied the model from a female and changed some of the settings like gender.
viebrix
Re: MPFB - AGE
Postby joepal » Wed Nov 09, 2022 12:13 pm
I've pushed a fix now, https://github.com/makehumancommunity/m ... 29f096f373
Hopefully this will prevent the crash from happening again.
If it still happens, it'd be helpful if you add additional info to https://github.com/makehumancommunity/mpfb2/issues/60
