Numeric input
Numeric input
Postby coz » Mon Oct 24, 2022 2:33 am
Hello,
I'd like if all parameters had numeric input boxes like the ones in the Meassure tab.
It doesn't matter if the value just goes from -1 to +1, or of it's a percentage.
I know I can edit the files manually. what I'd like is for this to be part of the UI.
Thoughts?
coz
Re: Numeric input
Postby Aranuvir » Mon Oct 24, 2022 5:49 pm
Try the latest alpha version. Can be activated under settings (right panel ;) ). Be aware, however, that these values are not from the real world, but represent the weight or strength of what is the equivalent to shape keys in Blender.
Re: Numeric input
Postby coz » Sat Oct 29, 2022 5:08 pm
Turns out the Blender plugin has numeric options, just not when creating; you can adjust numbers in the Model section.
And indeed, in the nightly build of MakeHuman there's "Slider's Edit Widget Visibility" which does what I want.
Thank you very much.
coz
