missing texture for hair but the texture is there
Postby jjones » Fri Jul 29, 2022 6:54 pm
Hello,
I'd like to use this cool hairstyle, but it comes out with an orange pattern instead of the embedded texture
I've looked in the folder that houses the files for this hairstyle which is called "Elvs_Maxwell_Hair"
and I found it in the community downloads area here: http://www.makehumancommunity.org/cloth ... _hair.html
$ ls
maxhairtex6.png maxwell_hair_mh.mhmat maxwell_hair_mh.mhpxy maxwell_hair_mh.obj
maxwell_hair_mh.mhclo maxwell_hair_mh.mhmat.backup maxwell_hair_mh.npz maxwell_hair_mh.thumb
I checked out the mhmat file and it references the maxhairtex6.png appropriately
The hair texture looks ok I guess
What could be the problem?
Thank you for any clues
-j_jones
jjones
Re: missing texture for hair but the texture is there
Postby jjones » Fri Jul 29, 2022 8:21 pm
Ok, I figured out that there were two copies of this hairstyle. One in the main source directory and one under the Documents folder.
I moved the folder called "maxwell" out from the main source directory: makehuman/makehuman/data/maxwell
and then I was able to get the hairstyle to render. It seems the two setting folders were interfering with each other.
It still has that funny sort of "tape" around the edges, though I've seen this artifact come and go with other models, so I'm not terribly worried about it.
Maybe this will help someone else
Thank you
-j jones
jjones
Postby joepal » Mon Aug 01, 2022 12:07 pm
The "tape" you're seeing is an image saying "texture not found". It gets loaded if a material references an image texture which does not exist.
