targets not mirrrored
Postby jojololo » Tue Apr 12, 2022 8:02 am
When reading the buttocks-volume-X.target, I wonder why the two files don't have the same vertices with inverted values.
What is the logic behind that?
I get I don't understand how targets are made since I need to create one from Blender.
But I like to understand what is going on underneath.
Thanks!
jojololo
Re: targets not mirrrored
Postby joepal » Sun Apr 17, 2022 5:32 pm
There is no linear mathematical relation between increasing and decreasing targets. They're just grouped because they relate to each other visually.
Take muscularity as an example. If you have a 0% muscular stomach you have a flabby beer belly. If you have a 100% muscular stomach, you have a six-pack. These are not morphologies that are linear mathematical opposites of each other. On one side of the spectrum you have bumpiness defining muscles, on the other you have a spherical shape with no defining topology.
The same is true for most positive/negative targets.
