Unable to save FACSHuman 0.1 slider positions
Postby Mr_Neffets » Wed Feb 02, 2022 12:17 am
Hello,
When saving models that utilize FACSHuman 0.1 (using the emotions blender, etc.) none of the settings in the FACSHuman 0.1 tab are saved with the model. Is this expected behavior/was this a feature that wasn't built into the plugin, or is there a way to fix this?
Any help is greatly appreciated, thanks!
Mr_Neffets
Re: Unable to save FACSHuman 0.1 slider positions
Postby loki1950 » Wed Feb 02, 2022 12:24 am
Why are you asking us we have no connection FACSHuman at all except that we can be imported into blender.
Postby Mr_Neffets » Wed Feb 02, 2022 12:27 am
loki1950 wrote:Why are you asking us we have no connection FACSHuman at all except that we can be imported into blender.
Ha, just about to come back here and say that I just saw on their page that the creators say to contact them instead of MakeHuman. I sent them an email. Free free to delete, but if I find a solution, I'll post it here just in case anyone has the same question.
Mr_Neffets
Postby Mr_Neffets » Wed Feb 02, 2022 1:10 am
I'm noticing now that the expression mixer also doesn't save expressions in the MHM file, but as a separate .mhpose file in the expressions folder, and doesn't load the last used expressions when opening a makehuman file. FACS does a similar thing, in which you can save an expression as a .facs file. This also does not load when opening an MHM file.
I suppose my one feature request would be to store the location of the last loaded .mhpose file and apply when loading back up an MHM file.
EDIT: The above feature does exist, if the expression was selection through the "Pose/Animate" tab it will load after saving. But slider positions will not be saved from the expression mixer tab.
Mr_Neffets
