MH Dual Graphic Cards on Linux not starting
Postby mene311 » Sun Nov 21, 2021 9:25 pm
Hi! I hope I get across enough info to make this productive.
I'm trying to run MH on Arch Linux, I've installed from the AUR both the 1.2.0-2 and the git one getting the same results
I'm on a laptop with 2 GPUs
CPU: AMD Ryzen 7 2700U with Radeon Vega Mobile Gfx (8) @ 2.200GHz
GPU: AMD ATI Radeon Vega Series / Radeon Vega Mobile Series
GPU: AMD ATI Radeon RX 560X
I'm guessing MH is trying to use the integrated one from the logs, but I couldn't find any info on how to force it to use the dedicated GPU (sorry :? )
MH Log
[2021-11-21 20:47:51,710] log.py->message():118 -- MESSAGE -- Initialized logging
[2021-11-21 20:47:51,714] log.py->debug():97 -- DEBUG -- VERSION: UNKNOWN:UNKNOWN
[2021-11-21 20:47:51,715] log.py->debug():97 -- DEBUG -- SHORT VERSION: alpha
[2021-11-21 20:47:51,715] log.py->debug():97 -- DEBUG -- LONG VERSION: 1.2.1 alpha (UNKNOWN:UNKNOWN)
[2021-11-21 20:47:51,715] log.py->debug():97 -- DEBUG -- BASEMESH VERSION: hm08
[2021-11-21 20:47:51,715] log.py->debug():97 -- DEBUG -- IS BUILT (FROZEN): No
[2021-11-21 20:47:51,715] log.py->debug():97 -- DEBUG -- IS RELEASE VERSION: No
[2021-11-21 20:47:51,715] log.py->debug():97 -- DEBUG -- DEFAULT ENCODING: utf-8
[2021-11-21 20:47:51,715] log.py->debug():97 -- DEBUG -- FILESYSTEM ENCODING: utf-8
[2021-11-21 20:47:51,715] log.py->debug():97 -- DEBUG -- STDOUT ENCODING: utf-8
[2021-11-21 20:47:51,715] log.py->debug():97 -- DEBUG -- LOCALE PREFERRED ENCODING: UTF-8
[2021-11-21 20:47:51,715] log.py->debug():97 -- DEBUG -- WORKING DIRECTORY: /opt/makehuman
[2021-11-21 20:47:51,715] log.py->debug():97 -- DEBUG -- HOME LOCATION: /home/mene/Documents
[2021-11-21 20:47:51,715] log.py->debug():97 -- DEBUG -- PYTHON PATH: ./:./lib:./apps:./shared:./apps/gui:./core:/opt/makehuman:/usr/lib/python39.zip:/usr/lib/python3.9:/usr/lib/python3.9/lib-dynload:/home/mene/.local/lib/python3.9/site-packages:/usr/lib/python3.9/site-packages
[2021-11-21 20:47:51,715] log.py->debug():97 -- DEBUG -- DLL PATH: /usr/local/sbin:/usr/local/bin:/usr/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl
[2021-11-21 20:47:51,715] log.py->debug():97 -- DEBUG -- SYS.VERSION: 3.9.7 (default, Oct 10 2021, 15:13:22)  [GCC 11.1.0]
[2021-11-21 20:47:51,715] log.py->debug():97 -- DEBUG -- SYS.PLATFORM: linux
[2021-11-21 20:47:51,715] log.py->debug():97 -- DEBUG -- SYS.EXECUTABLE: /usr/bin/python3
[2021-11-21 20:47:51,716] log.py->debug():97 -- DEBUG -- PLATFORM.MACHINE: x86_64
[2021-11-21 20:47:51,718] log.py->debug():97 -- DEBUG -- PLATFORM.PROCESSOR:
[2021-11-21 20:47:51,718] log.py->debug():97 -- DEBUG -- PLATFORM.UNAME.RELEASE: 5.15.2-arch1-1
[2021-11-21 20:47:51,719] log.py->debug():97 -- DEBUG -- PLATFORM.LINUX_DISTRIBUTION: Unknown
[2021-11-21 20:47:51,819] log.py->debug():97 -- DEBUG -- NUMPY.VERSION: 1.21.2
[2021-11-21 20:47:51,849] ctypesloader.py->_loadLibraryPosix():65 -- DEBUG -- Loaded libGL.so => libGL.so.1 <CDLL 'libGL.so.1', handle 55d786dcc220 at 0x7f7f9c107610>
[2021-11-21 20:47:51,850] acceleratesupport.py-><module>():17 -- MESSAGE -- No OpenGL_accelerate module loaded: No module named 'OpenGL_accelerate'
[2021-11-21 20:47:51,856] ctypesloader.py->_loadLibraryPosix():65 -- DEBUG -- Loaded libGLU.so => libGLU.so.1 <CDLL 'libGLU.so.1', handle 55d786de8250 at 0x7f7f9c20e280>
[2021-11-21 20:47:52,161] log.py->debug():97 -- DEBUG -- QT.VERSION: 5.15.2
[2021-11-21 20:47:52,163] log.py->debug():97 -- DEBUG -- QT.JPG_SUPPORT: supported
[2021-11-21 20:47:52,163] log.py->debug():97 -- DEBUG -- QT.SVG_SUPPORT: supported
[2021-11-21 20:47:52,163] log.py->debug():97 -- DEBUG -- QT.PLUGIN_PATH: /usr/lib/qt/plugins:/usr/bin
[2021-11-21 20:47:52,163] log.py->debug():97 -- DEBUG -- QT.PLUGIN_PATH_ENV:
[2021-11-21 20:47:52,163] log.py->debug():97 -- DEBUG -- QT.CONF: NOT PRESENT
[2021-11-21 20:47:52,252] log.py->debug():97 -- DEBUG -- PYOPENGL.VERSION: 3.1.5
[2021-11-21 20:47:52,253] log.py->debug():97 -- DEBUG -- NOSHADERS: not set
[2021-11-21 20:47:52,253] log.py->debug():97 -- DEBUG -- NOSAMPLEBUFFERS: not set
[2021-11-21 20:47:52,253] log.py->debug():97 -- DEBUG -- GL.VENDOR: AMD
[2021-11-21 20:47:52,253] log.py->debug():97 -- DEBUG -- GL.RENDERER: AMD Radeon Vega 3 Graphics (RAVEN, DRM 3.42.0, 5.15.2-arch1-1, LLVM 13.0.0)
[2021-11-21 20:47:52,253] log.py->debug():97 -- DEBUG -- GL.VERSION: 4.6 (Compatibility Profile) Mesa 21.2.5
[2021-11-21 20:47:52,253] log.py->debug():97 -- DEBUG -- 4.60
[2021-11-21 20:47:52,254] log.py->debug():97 -- DEBUG -- GLSL.VERSION: 4.60
[2021-11-21 20:47:52,255] log.py->debug():97 -- DEBUG -- GL.EXTENSION: GL_ARB_multisample not available (0x samples)
[2021-11-21 20:47:52,256] log.py->debug():97 -- DEBUG -- Creating new texture for image data/textures/texture_notfound.png.
[2021-11-21 20:47:52,260] log.py->debug():97 -- DEBUG -- GL.EXTENSION: GL_ARB_texture_non_power_of_two not available
[2021-11-21 20:47:52,263] log.py->debug():97 -- DEBUG -- initTexture: 256, 256, False
[2021-11-21 20:47:52,271] log.py->debug():97 -- DEBUG -- Setting language to english
[2021-11-21 20:47:52,271] log.py->warning():104 -- WARNING -- No settings file found, starting with default settings.
[2021-11-21 20:47:52,271] log.py->warning():104 -- WARNING -- Incompatible MakeHuman settings (version undefined) detected (expected 1.2.1). Loading default settings.
[2021-11-21 20:47:52,272] log.py->debug():97 -- DEBUG -- Setting language to english
[2021-11-21 20:47:52,272] log.py->warning():104 -- WARNING -- shortcuts.ini out of date; ignoring
[2021-11-21 20:47:52,272] log.py->message():118 -- MESSAGE -- Initializing default theme first.
[2021-11-21 20:47:52,272] log.py->message():118 -- MESSAGE -- Theme default version 1.2.0
[2021-11-21 20:47:52,273] log.py->debug():97 -- DEBUG -- Loaded theme data/themes/default.mht
[2021-11-21 20:47:52,274] log.py->debug():97 -- DEBUG -- Using Qt system style breeze
[2021-11-21 20:47:52,386] log.py->message():118 -- MESSAGE -- Loading human
[2021-11-21 20:47:52,390] log.py->debug():97 -- DEBUG -- Loading binary mesh data/3dobjs/base.npz.
[2021-11-21 20:47:52,400] log.py->debug():97 -- DEBUG -- NPZ-File: maxmimum number of faces for one vertex: 5
[2021-11-21 20:47:52,466] log.py->debug():97 -- DEBUG -- Loading material from file data/skins/default.mhmat
[2021-11-21 20:47:52,473] log.py->debug():97 -- DEBUG -- Shader: adding built-in uniform b'gl_NormalMatrix'
[2021-11-21 20:47:52,473] log.py->debug():97 -- DEBUG -- Shader: adding built-in uniform b'gl_ModelViewProjectionMatrix'
[2021-11-21 20:47:52,474] log.py->debug():97 -- DEBUG -- VectorUniform(AdditiveShading) = [0.]
[2021-11-21 20:47:52,604] log.py->message():118 -- MESSAGE -- Loaded vertex weights MakeHuman weights from file /opt/makehuman/data/rigs/default_weights.mhw
[2021-11-21 20:47:52,927] log.py->message():118 -- MESSAGE -- Loading scene
[2021-11-21 20:47:52,933] log.py->debug():97 -- DEBUG -- Loading scene file: data/scenes/default.mhscene
[2021-11-21 20:47:52,937] log.py->message():118 -- MESSAGE -- Loading main GUI
[2021-11-21 20:47:52,953] log.py->message():118 -- MESSAGE -- Loading plugins
[2021-11-21 20:47:52,962] log.py->message():118 -- MESSAGE -- Importing plugin 0_modeling_0_modifiers
[2021-11-21 20:47:52,975] log.py->message():118 -- MESSAGE -- Imported plugin 0_modeling_0_modifiers
[2021-11-21 20:47:52,978] log.py->message():118 -- MESSAGE -- Loading plugin 0_modeling_0_modifiers
[2021-11-21 20:47:52,981] log.py->debug():97 -- DEBUG -- Loading modifiers from data/modifiers/modeling_modifiers.json
[2021-11-21 20:47:52,981] log.py->debug():97 -- DEBUG -- Attempting to load targets from NPZ file.
[2021-11-21 20:47:53,232] log.py->debug():97 -- DEBUG -- 1280 targets loaded from NPZ file succesfully.
[2021-11-21 20:47:53,986] log.py->message():118 -- MESSAGE -- Loaded 249 modifiers from file data/modifiers/modeling_modifiers.json
[2021-11-21 20:47:53,988] log.py->message():118 -- MESSAGE -- Loaded 249 modifier descriptions from file data/modifiers/modeling_modifiers_desc.json
[2021-11-21 20:47:54,249] log.py->message():118 -- MESSAGE -- Loaded plugin 0_modeling_0_modifiers
[2021-11-21 20:47:54,263] log.py->message():118 -- MESSAGE -- Importing plugin 0_modeling_1_bodyshapes
[2021-11-21 20:47:54,265] log.py->message():118 -- MESSAGE -- Imported plugin 0_modeling_1_bodyshapes
[2021-11-21 20:47:54,266] log.py->message():118 -- MESSAGE -- Loading plugin 0_modeling_1_bodyshapes
[2021-11-21 20:47:54,267] log.py->debug():97 -- DEBUG -- Loading modifiers from data/modifiers/bodyshapes_modifiers.json
[2021-11-21 20:47:54,268] log.py->message():118 -- MESSAGE -- Loaded 22 modifiers from file data/modifiers/bodyshapes_modifiers.json
[2021-11-21 20:47:54,269] log.py->message():118 -- MESSAGE -- Loaded 22 modifier descriptions from file data/modifiers/bodyshapes_modifiers_desc.json
[2021-11-21 20:47:54,302] log.py->message():118 -- MESSAGE -- Loaded plugin 0_modeling_1_bodyshapes
[2021-11-21 20:47:54,306] log.py->message():118 -- MESSAGE -- Importing plugin 0_modeling_8_random
[2021-11-21 20:47:54,308] log.py->message():118 -- MESSAGE -- Imported plugin 0_modeling_8_random
[2021-11-21 20:47:54,310] log.py->message():118 -- MESSAGE -- Loading plugin 0_modeling_8_random
[2021-11-21 20:47:54,315] log.py->message():118 -- MESSAGE -- Loaded plugin 0_modeling_8_random
[2021-11-21 20:47:54,317] log.py->message():118 -- MESSAGE -- Importing plugin 0_modeling_9_custom_targets
[2021-11-21 20:47:54,320] log.py->message():118 -- MESSAGE -- Imported plugin 0_modeling_9_custom_targets
[2021-11-21 20:47:54,321] log.py->message():118 -- MESSAGE -- Loading plugin 0_modeling_9_custom_targets
[2021-11-21 20:47:54,324] log.py->message():118 -- MESSAGE -- Loaded plugin 0_modeling_9_custom_targets
[2021-11-21 20:47:54,327] log.py->message():118 -- MESSAGE -- Importing plugin 0_modeling_a_measurement
[2021-11-21 20:47:54,332] log.py->message():118 -- MESSAGE -- Imported plugin 0_modeling_a_measurement
[2021-11-21 20:47:54,333] log.py->message():118 -- MESSAGE -- Loading plugin 0_modeling_a_measurement
[2021-11-21 20:47:54,334] log.py->debug():97 -- DEBUG -- Loading modifiers from data/modifiers/measurement_modifiers.json
[2021-11-21 20:47:54,335] log.py->message():118 -- MESSAGE -- Loaded 20 modifiers from file data/modifiers/measurement_modifiers.json
[2021-11-21 20:47:54,336] log.py->message():118 -- MESSAGE -- Loaded 20 modifier descriptions from file data/modifiers/measurement_modifiers_desc.json
[2021-11-21 20:47:54,363] log.py->message():118 -- MESSAGE -- Loaded plugin 0_modeling_a_measurement
[2021-11-21 20:47:54,369] log.py->message():118 -- MESSAGE -- Importing plugin 0_modeling_background
[2021-11-21 20:47:54,382] log.py->message():118 -- MESSAGE -- Imported plugin 0_modeling_background
[2021-11-21 20:47:54,385] log.py->message():118 -- MESSAGE -- Loading plugin 0_modeling_background
[2021-11-21 20:47:54,399] log.py->message():118 -- MESSAGE -- Loaded plugin 0_modeling_background
[2021-11-21 20:47:54,404] log.py->message():118 -- MESSAGE -- Importing plugin 1_convert_model_tags
[2021-11-21 20:47:54,407] log.py->message():118 -- MESSAGE -- Imported plugin 1_convert_model_tags
[2021-11-21 20:47:54,408] log.py->message():118 -- MESSAGE -- Loading plugin 1_convert_model_tags
[2021-11-21 20:47:54,410] log.py->message():118 -- MESSAGE -- Loaded plugin 1_convert_model_tags
[2021-11-21 20:47:54,412] log.py->message():118 -- MESSAGE -- Importing plugin 2_foot_posing
[2021-11-21 20:47:54,420] log.py->message():118 -- MESSAGE -- Imported plugin 2_foot_posing
[2021-11-21 20:47:54,422] log.py->message():118 -- MESSAGE -- Loading plugin 2_foot_posing
[2021-11-21 20:47:54,423] log.py->message():118 -- MESSAGE -- Loaded plugin 2_foot_posing
[2021-11-21 20:47:54,425] log.py->message():118 -- MESSAGE -- Importing plugin 2_posing_expression
[2021-11-21 20:47:54,428] log.py->message():118 -- MESSAGE -- Imported plugin 2_posing_expression
[2021-11-21 20:47:54,430] log.py->message():118 -- MESSAGE -- Loading plugin 2_posing_expression
[2021-11-21 20:47:54,434] log.py->message():118 -- MESSAGE -- Loaded plugin 2_posing_expression
[2021-11-21 20:47:54,436] log.py->message():118 -- MESSAGE -- Importing plugin 3_libraries_animation
[2021-11-21 20:47:54,438] log.py->message():118 -- MESSAGE -- Imported plugin 3_libraries_animation
[2021-11-21 20:47:54,439] log.py->message():118 -- MESSAGE -- Loading plugin 3_libraries_animation
[2021-11-21 20:47:54,441] log.py->message():118 -- MESSAGE -- Loaded plugin 3_libraries_animation
[2021-11-21 20:47:54,444] log.py->message():118 -- MESSAGE -- Importing plugin 3_libraries_clothes_chooser
[2021-11-21 20:47:54,459] log.py->message():118 -- MESSAGE -- Imported plugin 3_libraries_clothes_chooser
[2021-11-21 20:47:54,462] log.py->message():118 -- MESSAGE -- Loading plugin 3_libraries_clothes_chooser
[2021-11-21 20:47:54,468] log.py->message():118 -- MESSAGE -- Loaded plugin 3_libraries_clothes_chooser
[2021-11-21 20:47:54,470] log.py->message():118 -- MESSAGE -- Importing plugin 3_libraries_eye_chooser
[2021-11-21 20:47:54,472] log.py->message():118 -- MESSAGE -- Imported plugin 3_libraries_eye_chooser
[2021-11-21 20:47:54,473] log.py->message():118 -- MESSAGE -- Loading plugin 3_libraries_eye_chooser
[2021-11-21 20:47:54,477] log.py->debug():97 -- DEBUG -- According to mh.getSysDataPath here's high poly eyes data/eyes/high-poly/high-poly.mhclo
[2021-11-21 20:47:54,478] log.py->message():118 -- MESSAGE -- Selecting proxy file "data/eyes/high-poly/high-poly.mhclo" from eyes library.
[2021-11-21 20:47:54,481] log.py->debug():97 -- DEBUG -- Loading binary proxy data/eyes/high-poly/high-poly.mhpxy.
[2021-11-21 20:47:54,481] log.py->debug():97 -- DEBUG -- Loading proxy file: data/eyes/high-poly/high-poly.mhpxy.
[2021-11-21 20:47:54,494] log.py->debug():97 -- DEBUG -- Loading material from file /opt/makehuman/data/eyes/materials/brown.mhmat
[2021-11-21 20:47:54,497] log.py->debug():97 -- DEBUG -- Shader: adding built-in uniform b'gl_NormalMatrix'
[2021-11-21 20:47:54,498] log.py->debug():97 -- DEBUG -- Shader: adding built-in uniform b'gl_ModelViewProjectionMatrix'
[2021-11-21 20:47:54,499] log.py->debug():97 -- DEBUG -- VectorUniform(AdditiveShading) = [0.]
[2021-11-21 20:47:54,500] log.py->debug():97 -- DEBUG -- Loading binary mesh /opt/makehuman/data/eyes/high-poly/high-poly.npz.
[2021-11-21 20:47:54,501] log.py->debug():97 -- DEBUG -- NPZ-File: maxmimum number of faces for one vertex: 4
[2021-11-21 20:47:54,509] log.py->debug():97 -- DEBUG -- remapping weights for proxy HighPolyEyes
[2021-11-21 20:47:54,546] log.py->debug():97 -- DEBUG -- remapping weights for HighPolyEyes took 0.03450 seconds
[2021-11-21 20:47:54,594] log.py->message():118 -- MESSAGE -- Loaded plugin 3_libraries_eye_chooser
[2021-11-21 20:47:54,596] log.py->message():118 -- MESSAGE -- Importing plugin 3_libraries_eyebrows
[2021-11-21 20:47:54,598] log.py->message():118 -- MESSAGE -- Imported plugin 3_libraries_eyebrows
[2021-11-21 20:47:54,600] log.py->message():118 -- MESSAGE -- Loading plugin 3_libraries_eyebrows
[2021-11-21 20:47:54,604] log.py->message():118 -- MESSAGE -- Loaded plugin 3_libraries_eyebrows
[2021-11-21 20:47:54,606] log.py->message():118 -- MESSAGE -- Importing plugin 3_libraries_eyelashes
[2021-11-21 20:47:54,608] log.py->message():118 -- MESSAGE -- Imported plugin 3_libraries_eyelashes
[2021-11-21 20:47:54,609] log.py->message():118 -- MESSAGE -- Loading plugin 3_libraries_eyelashes
[2021-11-21 20:47:54,613] log.py->message():118 -- MESSAGE -- Loaded plugin 3_libraries_eyelashes
[2021-11-21 20:47:54,615] log.py->message():118 -- MESSAGE -- Importing plugin 3_libraries_material_chooser
[2021-11-21 20:47:54,620] log.py->message():118 -- MESSAGE -- Imported plugin 3_libraries_material_chooser
[2021-11-21 20:47:54,621] log.py->message():118 -- MESSAGE -- Loading plugin 3_libraries_material_chooser
[2021-11-21 20:47:54,627] log.py->message():118 -- MESSAGE -- Loaded plugin 3_libraries_material_chooser
[2021-11-21 20:47:54,630] log.py->message():118 -- MESSAGE -- Importing plugin 3_libraries_polygon_hair_chooser
[2021-11-21 20:47:54,632] log.py->message():118 -- MESSAGE -- Imported plugin 3_libraries_polygon_hair_chooser
[2021-11-21 20:47:54,634] log.py->message():118 -- MESSAGE -- Loading plugin 3_libraries_polygon_hair_chooser
[2021-11-21 20:47:54,639] log.py->message():118 -- MESSAGE -- Loaded plugin 3_libraries_polygon_hair_chooser
[2021-11-21 20:47:54,642] log.py->message():118 -- MESSAGE -- Importing plugin 3_libraries_pose
[2021-11-21 20:47:54,646] log.py->message():118 -- MESSAGE -- Imported plugin 3_libraries_pose
[2021-11-21 20:47:54,648] log.py->message():118 -- MESSAGE -- Loading plugin 3_libraries_pose
[2021-11-21 20:47:54,652] log.py->message():118 -- MESSAGE -- Loaded plugin 3_libraries_pose
[2021-11-21 20:47:54,654] log.py->message():118 -- MESSAGE -- Importing plugin 3_libraries_proxy_chooser
[2021-11-21 20:47:54,657] log.py->message():118 -- MESSAGE -- Imported plugin 3_libraries_proxy_chooser
[2021-11-21 20:47:54,658] log.py->message():118 -- MESSAGE -- Loading plugin 3_libraries_proxy_chooser
[2021-11-21 20:47:54,663] log.py->message():118 -- MESSAGE -- Loaded plugin 3_libraries_proxy_chooser
[2021-11-21 20:47:54,666] log.py->message():118 -- MESSAGE -- Importing plugin 3_libraries_skeleton
[2021-11-21 20:47:54,671] log.py->message():118 -- MESSAGE -- Imported plugin 3_libraries_skeleton
[2021-11-21 20:47:54,673] log.py->message():118 -- MESSAGE -- Loading plugin 3_libraries_skeleton
[2021-11-21 20:47:54,681] log.py->message():118 -- MESSAGE -- Loaded plugin 3_libraries_skeleton
[2021-11-21 20:47:54,686] log.py->message():118 -- MESSAGE -- Importing plugin 3_libraries_teeth
[2021-11-21 20:47:54,688] log.py->message():118 -- MESSAGE -- Imported plugin 3_libraries_teeth
[2021-11-21 20:47:54,690] log.py->message():118 -- MESSAGE -- Loading plugin 3_libraries_teeth
[2021-11-21 20:47:54,694] log.py->message():118 -- MESSAGE -- Loaded plugin 3_libraries_teeth
[2021-11-21 20:47:54,698] log.py->message():118 -- MESSAGE -- Importing plugin 3_libraries_tongue
[2021-11-21 20:47:54,700] log.py->message():118 -- MESSAGE -- Imported plugin 3_libraries_tongue
[2021-11-21 20:47:54,702] log.py->message():118 -- MESSAGE -- Loading plugin 3_libraries_tongue
[2021-11-21 20:47:54,706] log.py->message():118 -- MESSAGE -- Loaded plugin 3_libraries_tongue
[2021-11-21 20:47:54,708] log.py->message():118 -- MESSAGE -- Importing plugin 4_rendering_9_viewer
[2021-11-21 20:47:54,710] log.py->message():118 -- MESSAGE -- Imported plugin 4_rendering_9_viewer
[2021-11-21 20:47:54,712] log.py->message():118 -- MESSAGE -- Loading plugin 4_rendering_9_viewer
[2021-11-21 20:47:54,716] log.py->message():118 -- MESSAGE -- Loaded plugin 4_rendering_9_viewer
[2021-11-21 20:47:54,718] log.py->message():118 -- MESSAGE -- Importing plugin 4_rendering_opengl
[2021-11-21 20:47:54,722] log.py->message():118 -- MESSAGE -- Imported plugin 4_rendering_opengl
[2021-11-21 20:47:54,724] log.py->message():118 -- MESSAGE -- Loading plugin 4_rendering_opengl
[2021-11-21 20:47:54,729] log.py->message():118 -- MESSAGE -- Loaded plugin 4_rendering_opengl
[2021-11-21 20:47:54,733] log.py->message():118 -- MESSAGE -- Importing plugin 4_rendering_scene
[2021-11-21 20:47:54,736] log.py->message():118 -- MESSAGE -- Imported plugin 4_rendering_scene
[2021-11-21 20:47:54,737] log.py->message():118 -- MESSAGE -- Loading plugin 4_rendering_scene
[2021-11-21 20:47:54,739] mhmain.py->addSetting():353 -- NOTICE -- Setting rendering_width is already declared. Adding it again has no effect.
[2021-11-21 20:47:54,741] mhmain.py->addSetting():353 -- NOTICE -- Setting rendering_height is already declared. Adding it again has no effect.
[2021-11-21 20:47:54,744] log.py->message():118 -- MESSAGE -- Loaded plugin 4_rendering_scene
[2021-11-21 20:47:54,748] log.py->message():118 -- MESSAGE -- Importing plugin 5_settings_0_settings
[2021-11-21 20:47:54,752] log.py->message():118 -- MESSAGE -- Imported plugin 5_settings_0_settings
[2021-11-21 20:47:54,754] log.py->message():118 -- MESSAGE -- Loading plugin 5_settings_0_settings
[2021-11-21 20:47:54,965] log.py->debug():97 -- DEBUG -- Setting language to english
[2021-11-21 20:47:54,966] log.py->message():118 -- MESSAGE -- Theme makehuman version 1.2.0
[2021-11-21 20:47:54,972] log.py->debug():97 -- DEBUG -- Loaded theme data/themes/makehuman.mht
[2021-11-21 20:47:56,568] log.py->debug():97 -- DEBUG -- Loaded Qt style data/themes/makehuman.qss
[2021-11-21 20:47:56,596] log.py->message():118 -- MESSAGE -- Loaded plugin 5_settings_0_settings
[2021-11-21 20:47:56,602] log.py->message():118 -- MESSAGE -- Importing plugin 5_settings_mouse
[2021-11-21 20:47:56,604] log.py->message():118 -- MESSAGE -- Imported plugin 5_settings_mouse
[2021-11-21 20:47:56,606] log.py->message():118 -- MESSAGE -- Loading plugin 5_settings_mouse
[2021-11-21 20:47:56,613] log.py->message():118 -- MESSAGE -- Loaded plugin 5_settings_mouse
[2021-11-21 20:47:56,617] log.py->message():118 -- MESSAGE -- Importing plugin 5_settings_shortcuts
[2021-11-21 20:47:56,620] log.py->message():118 -- MESSAGE -- Imported plugin 5_settings_shortcuts
[2021-11-21 20:47:56,621] log.py->message():118 -- MESSAGE -- Loading plugin 5_settings_shortcuts
[2021-11-21 20:47:56,650] log.py->message():118 -- MESSAGE -- Loaded plugin 5_settings_shortcuts
[2021-11-21 20:47:56,654] log.py->message():118 -- MESSAGE -- Importing plugin 5_settings_userplugins
[2021-11-21 20:47:56,659] log.py->message():118 -- MESSAGE -- Imported plugin 5_settings_userplugins
[2021-11-21 20:47:56,660] log.py->message():118 -- MESSAGE -- Loading plugin 5_settings_userplugins
[2021-11-21 20:47:56,670] log.py->message():118 -- MESSAGE -- Loaded plugin 5_settings_userplugins
[2021-11-21 20:47:56,675] log.py->message():118 -- MESSAGE -- Importing plugin 6_help
[2021-11-21 20:47:56,680] log.py->message():118 -- MESSAGE -- Imported plugin 6_help
[2021-11-21 20:47:56,682] log.py->message():118 -- MESSAGE -- Loading plugin 6_help
[2021-11-21 20:47:56,691] log.py->message():118 -- MESSAGE -- Loaded plugin 6_help
[2021-11-21 20:47:56,698] log.py->message():118 -- MESSAGE -- Importing plugin 7_data
[2021-11-21 20:47:56,702] log.py->message():118 -- MESSAGE -- Imported plugin 7_data
[2021-11-21 20:47:56,704] log.py->message():118 -- MESSAGE -- Loading plugin 7_data
[2021-11-21 20:47:56,719] log.py->message():118 -- MESSAGE -- Loaded plugin 7_data
[2021-11-21 20:47:56,725] log.py->message():118 -- MESSAGE -- Importing plugin 7_example
[2021-11-21 20:47:56,730] log.py->message():118 -- MESSAGE -- Imported plugin 7_example
[2021-11-21 20:47:56,732] log.py->message():118 -- MESSAGE -- Loading plugin 7_example
[2021-11-21 20:47:56,742] log.py->message():118 -- MESSAGE -- Loaded plugin 7_example
[2021-11-21 20:47:56,746] log.py->message():118 -- MESSAGE -- Importing plugin 7_expression_mixer
[2021-11-21 20:47:56,751] log.py->message():118 -- MESSAGE -- Imported plugin 7_expression_mixer
[2021-11-21 20:47:56,752] log.py->message():118 -- MESSAGE -- Loading plugin 7_expression_mixer
[2021-11-21 20:47:56,768] log.py->message():118 -- MESSAGE -- Loaded plugin 7_expression_mixer
[2021-11-21 20:47:56,772] log.py->message():118 -- MESSAGE -- Importing plugin 7_logging
[2021-11-21 20:47:56,774] log.py->message():118 -- MESSAGE -- Imported plugin 7_logging
[2021-11-21 20:47:56,776] log.py->message():118 -- MESSAGE -- Loading plugin 7_logging
[2021-11-21 20:47:56,794] log.py->message():118 -- MESSAGE -- Loaded plugin 7_logging
[2021-11-21 20:47:56,798] log.py->message():118 -- MESSAGE -- Importing plugin 7_material_editor
[2021-11-21 20:47:56,809] log.py->message():118 -- MESSAGE -- Imported plugin 7_material_editor
[2021-11-21 20:47:56,815] log.py->message():118 -- MESSAGE -- Loading plugin 7_material_editor
[2021-11-21 20:47:56,837] log.py->message():118 -- MESSAGE -- Loaded plugin 7_material_editor
[2021-11-21 20:47:56,841] log.py->message():118 -- MESSAGE -- Importing plugin 7_profile
[2021-11-21 20:47:56,849] log.py->message():118 -- MESSAGE -- Imported plugin 7_profile
[2021-11-21 20:47:56,850] log.py->message():118 -- MESSAGE -- Loading plugin 7_profile
[2021-11-21 20:47:56,867] log.py->message():118 -- MESSAGE -- Loaded plugin 7_profile
[2021-11-21 20:47:56,872] log.py->message():118 -- MESSAGE -- Importing plugin 7_save_targets
[2021-11-21 20:47:56,878] log.py->message():118 -- MESSAGE -- Imported plugin 7_save_targets
[2021-11-21 20:47:56,880] log.py->message():118 -- MESSAGE -- Loading plugin 7_save_targets
[2021-11-21 20:47:56,894] log.py->message():118 -- MESSAGE -- Loaded plugin 7_save_targets
[2021-11-21 20:47:56,899] log.py->message():118 -- MESSAGE -- Importing plugin 7_scene_editor
[2021-11-21 20:47:56,904] log.py->message():118 -- MESSAGE -- Imported plugin 7_scene_editor
[2021-11-21 20:47:56,905] log.py->message():118 -- MESSAGE -- Loading plugin 7_scene_editor
[2021-11-21 20:47:56,907] mhmain.py->addSetting():353 -- NOTICE -- Setting rendering_width is already declared. Adding it again has no effect.
[2021-11-21 20:47:56,911] mhmain.py->addSetting():353 -- NOTICE -- Setting rendering_height is already declared. Adding it again has no effect.
[2021-11-21 20:47:56,920] log.py->message():118 -- MESSAGE -- Loaded plugin 7_scene_editor
[2021-11-21 20:47:56,923] log.py->message():118 -- MESSAGE -- Importing plugin 7_scripting
[2021-11-21 20:47:56,929] log.py->message():118 -- MESSAGE -- Imported plugin 7_scripting
[2021-11-21 20:47:56,931] log.py->message():118 -- MESSAGE -- Loading plugin 7_scripting
[2021-11-21 20:47:56,945] log.py->message():118 -- MESSAGE -- Loaded plugin 7_scripting
[2021-11-21 20:47:56,951] log.py->message():118 -- MESSAGE -- Importing plugin 7_shell
[2021-11-21 20:47:56,954] log.py->message():118 -- MESSAGE -- Imported plugin 7_shell
[2021-11-21 20:47:56,955] log.py->message():118 -- MESSAGE -- Loading plugin 7_shell
[2021-11-21 20:47:56,960] log.py->message():118 -- MESSAGE -- Loaded plugin 7_shell
[2021-11-21 20:47:56,965] log.py->message():118 -- MESSAGE -- Importing plugin 7_targets
[2021-11-21 20:47:56,968] log.py->message():118 -- MESSAGE -- Imported plugin 7_targets
[2021-11-21 20:47:56,970] log.py->message():118 -- MESSAGE -- Loading plugin 7_targets
[2021-11-21 20:47:56,978] log.py->message():118 -- MESSAGE -- Loaded plugin 7_targets
[2021-11-21 20:47:56,981] log.py->message():118 -- MESSAGE -- Importing plugin 9_export_bvh
[2021-11-21 20:47:56,985] log.py->message():118 -- MESSAGE -- Imported plugin 9_export_bvh
[2021-11-21 20:47:56,986] log.py->message():118 -- MESSAGE -- Loading plugin 9_export_bvh
[2021-11-21 20:47:56,990] log.py->message():118 -- MESSAGE -- Loaded plugin 9_export_bvh
[2021-11-21 20:47:56,994] log.py->message():118 -- MESSAGE -- Importing plugin 9_export_collada
[2021-11-21 20:47:56,997] log.py->message():118 -- MESSAGE -- Imported plugin 9_export_collada
[2021-11-21 20:47:56,998] log.py->message():118 -- MESSAGE -- Loading plugin 9_export_collada
[2021-11-21 20:47:57,003] log.py->message():118 -- MESSAGE -- Loaded plugin 9_export_collada
[2021-11-21 20:47:57,005] log.py->message():118 -- MESSAGE -- Importing plugin 9_export_fbx
[2021-11-21 20:47:57,008] log.py->message():118 -- MESSAGE -- Imported plugin 9_export_fbx
[2021-11-21 20:47:57,010] log.py->message():118 -- MESSAGE -- Loading plugin 9_export_fbx
[2021-11-21 20:47:57,015] log.py->message():118 -- MESSAGE -- Loaded plugin 9_export_fbx
[2021-11-21 20:47:57,017] log.py->message():118 -- MESSAGE -- Importing plugin 9_export_light
[2021-11-21 20:47:57,019] log.py->message():118 -- MESSAGE -- Imported plugin 9_export_light
[2021-11-21 20:47:57,020] log.py->message():118 -- MESSAGE -- Loading plugin 9_export_light
[2021-11-21 20:47:57,022] log.py->message():118 -- MESSAGE -- Loaded plugin 9_export_light
[2021-11-21 20:47:57,024] log.py->message():118 -- MESSAGE -- Importing plugin 9_export_obj
[2021-11-21 20:47:57,026] log.py->message():118 -- MESSAGE -- Imported plugin 9_export_obj
[2021-11-21 20:47:57,028] log.py->message():118 -- MESSAGE -- Loading plugin 9_export_obj
[2021-11-21 20:47:57,032] log.py->message():118 -- MESSAGE -- Loaded plugin 9_export_obj
[2021-11-21 20:47:57,034] log.py->message():118 -- MESSAGE -- Importing plugin 9_export_ogre
[2021-11-21 20:47:57,039] log.py->message():118 -- MESSAGE -- Imported plugin 9_export_ogre
[2021-11-21 20:47:57,040] log.py->message():118 -- MESSAGE -- Loading plugin 9_export_ogre
[2021-11-21 20:47:57,043] log.py->message():118 -- MESSAGE -- Loaded plugin 9_export_ogre
[2021-11-21 20:47:57,046] log.py->message():118 -- MESSAGE -- Importing plugin 9_export_stl
[2021-11-21 20:47:57,050] log.py->message():118 -- MESSAGE -- Imported plugin 9_export_stl
[2021-11-21 20:47:57,051] log.py->message():118 -- MESSAGE -- Loading plugin 9_export_stl
[2021-11-21 20:47:57,054] log.py->message():118 -- MESSAGE -- Loaded plugin 9_export_stl
[2021-11-21 20:47:57,056] log.py->message():118 -- MESSAGE -- Importing plugin 9_export_uvmap
[2021-11-21 20:47:57,057] log.py->message():118 -- MESSAGE -- Imported plugin 9_export_uvmap
[2021-11-21 20:47:57,059] log.py->message():118 -- MESSAGE -- Loading plugin 9_export_uvmap
[2021-11-21 20:47:57,061] log.py->message():118 -- MESSAGE -- Loaded plugin 9_export_uvmap
[2021-11-21 20:47:57,064] log.py->message():118 -- MESSAGE -- Loading GUI
[2021-11-21 20:47:57,091] log.py->debug():97 -- DEBUG -- showing category Modelling
[2021-11-21 20:47:57,091] log.py->debug():97 -- DEBUG -- showing task Macro modelling
[2021-11-21 20:47:57,286] log.py->message():118 -- MESSAGE -- Loading theme
[2021-11-21 20:47:57,288] log.py->message():118 -- MESSAGE -- Theme makehuman version 1.2.0
[2021-11-21 20:47:57,291] log.py->debug():97 -- DEBUG -- Loaded theme data/themes/makehuman.mht
[2021-11-21 20:48:00,108] log.py->debug():97 -- DEBUG -- Loaded Qt style data/themes/makehuman.qss
[2021-11-21 20:48:00,127] log.py->message():118 -- MESSAGE -- Applying targets
[2021-11-21 20:48:00,269] log.py->debug():97 -- DEBUG -- Updating skeleton joint positions
[2021-11-21 20:48:00,339] log.py->debug():97 -- DEBUG -- Done baking animations
[2021-11-21 20:48:00,395] log.py->message():118 -- MESSAGE -- Loading macro targets
[2021-11-21 20:48:00,397] log.py->message():118 -- MESSAGE -- Loading done
[2021-11-21 20:48:00,399] log.py->message():118 -- MESSAGE --
MH Debug
SYS.PLATFORM: linux
PLATFORM.PROCESSOR:
QT.VERSION: 5.15.2
QT.PLUGIN_PATH_ENV:
NOSHADERS: not set
GL.VENDOR: AMD
GLSL.VERSION: 4.60
mene311
Re: MH Dual Graphic Cards on Linux not starting
Postby Aranuvir » Tue Nov 23, 2021 8:45 pm
Can you try to permanently force the usage of your dGPU in the driver settings? (I've stopped using PRIME on my laptop, though my PRIME experience on my AMD-laptop was much better than on my new NVIDIA-laptop.)
Perhaps using something like:
$ DRI_PRIME=1 ./makehuman
can help, too... (and should be working with your dGPU on demand).
Users browsing this forum: onder and 1 guest
