asset downloader
asset downloader
Postby williamb » Wed Nov 25, 2020 2:30 pm
Could not load 8_asset_downloader
File "./core\mhmain.py", line 583, in loadPlugin
module.load(self)
File "C:\Users\wlb41\AppData\Local\makehuman-community\makehuman\plugins\8_asset_downloader\__init__.py", line 38, in load
downloadView = category.addTask(AssetDownloadTaskView(category))
File "C:\Users\wlb41\AppData\Local\makehuman-community\makehuman\plugins\8_asset_downloader\assetdownload.py", line 72, in __init__
self.assetdb = AssetDB(self)
File "C:\Users\wlb41\AppData\Local\makehuman-community\makehuman\plugins\8_asset_downloader\assetdb.py", line 67, in __init__
self._loadRemoteDB()
File "C:\Users\wlb41\AppData\Local\makehuman-community\makehuman\plugins\8_asset_downloader\assetdb.py", line 92, in _loadRemoteDB
self.remoteJson = json.load(f)
File "D:\obj\windows-release\37amd64_Release\msi_python\zip_amd64\__init__.py", line 296, in load
File "D:\obj\windows-release\37amd64_Release\msi_python\zip_amd64\__init__.py", line 348, in loads
File "D:\obj\windows-release\37amd64_Release\msi_python\zip_amd64\decoder.py", line 337, in decode
File "D:\obj\windows-release\37amd64_Release\msi_python\zip_amd64\decoder.py", line 353, in raw_decode
json.decoder.JSONDecodeError: Expecting property name enclosed in double quotes: line 1268 column 6 (char 79859)
This is the error I get. Makehuman works fine but I can't access the asset downloader. I have uninstalled and reinstalled I tried the latest nightly build but no luck. It seems to work fine with Blender.
williamb
Re: asset downloader
Postby joepal » Wed Nov 25, 2020 4:59 pm
This looks very, very strange. Can you post the entire log as an attachment here?
Postby williamb » Wed Nov 25, 2020 6:45 pm
Initializing default theme first.
Theme default version 1.2.0
Loading human
Loaded vertex weights MakeHuman weights from file C:/Users/wlb41/AppData/Local/makehuman-community/makehuman/data/rigs/default_weights.mhw
Loading scene
Loading main GUI
Loading plugins
Importing plugin 0_modeling_0_modifiers
Imported plugin 0_modeling_0_modifiers
Loading plugin 0_modeling_0_modifiers
Loaded 249 modifiers from file data/modifiers/modeling_modifiers.json
Loaded 249 modifier descriptions from file data/modifiers/modeling_modifiers_desc.json
Loaded plugin 0_modeling_0_modifiers
Importing plugin 0_modeling_8_random
Imported plugin 0_modeling_8_random
Loading plugin 0_modeling_8_random
Loaded plugin 0_modeling_8_random
Importing plugin 0_modeling_9_custom_targets
Imported plugin 0_modeling_9_custom_targets
Loading plugin 0_modeling_9_custom_targets
Loaded plugin 0_modeling_9_custom_targets
Importing plugin 0_modeling_a_measurement
Imported plugin 0_modeling_a_measurement
Loading plugin 0_modeling_a_measurement
Loaded 20 modifiers from file data/modifiers/measurement_modifiers.json
Loaded 20 modifier descriptions from file data/modifiers/measurement_modifiers_desc.json
Loaded plugin 0_modeling_a_measurement
Importing plugin 0_modeling_background
Imported plugin 0_modeling_background
Loading plugin 0_modeling_background
Loaded plugin 0_modeling_background
Importing plugin 1_convert_model_tags
Imported plugin 1_convert_model_tags
Loading plugin 1_convert_model_tags
Loaded plugin 1_convert_model_tags
Importing plugin 1_mhapi
Imported plugin 1_mhapi
Loading plugin 1_mhapi
Loaded plugin 1_mhapi
Importing plugin 2_foot_posing
Imported plugin 2_foot_posing
Loading plugin 2_foot_posing
Loaded plugin 2_foot_posing
Importing plugin 2_posing_expression
Imported plugin 2_posing_expression
Loading plugin 2_posing_expression
Loaded plugin 2_posing_expression
Importing plugin 3_libraries_clothes_chooser
Imported plugin 3_libraries_clothes_chooser
Loading plugin 3_libraries_clothes_chooser
Loaded plugin 3_libraries_clothes_chooser
Importing plugin 3_libraries_eye_chooser
Imported plugin 3_libraries_eye_chooser
Loading plugin 3_libraries_eye_chooser
Selecting proxy file "data/eyes/high-poly/high-poly.mhclo" from eyes library.
Loaded plugin 3_libraries_eye_chooser
Importing plugin 3_libraries_eyebrows
Imported plugin 3_libraries_eyebrows
Loading plugin 3_libraries_eyebrows
Loaded plugin 3_libraries_eyebrows
Importing plugin 3_libraries_eyelashes
Imported plugin 3_libraries_eyelashes
Loading plugin 3_libraries_eyelashes
Loaded plugin 3_libraries_eyelashes
Importing plugin 3_libraries_material_chooser
Imported plugin 3_libraries_material_chooser
Loading plugin 3_libraries_material_chooser
Loaded plugin 3_libraries_material_chooser
Importing plugin 3_libraries_polygon_hair_chooser
Imported plugin 3_libraries_polygon_hair_chooser
Loading plugin 3_libraries_polygon_hair_chooser
Loaded plugin 3_libraries_polygon_hair_chooser
Importing plugin 3_libraries_pose
Imported plugin 3_libraries_pose
Loading plugin 3_libraries_pose
Loaded plugin 3_libraries_pose
Importing plugin 3_libraries_proxy_chooser
Imported plugin 3_libraries_proxy_chooser
Loading plugin 3_libraries_proxy_chooser
Loaded plugin 3_libraries_proxy_chooser
Importing plugin 3_libraries_skeleton
Imported plugin 3_libraries_skeleton
Loading plugin 3_libraries_skeleton
Loaded plugin 3_libraries_skeleton
Importing plugin 3_libraries_teeth
Imported plugin 3_libraries_teeth
Loading plugin 3_libraries_teeth
Loaded plugin 3_libraries_teeth
Importing plugin 3_libraries_tongue
Imported plugin 3_libraries_tongue
Loading plugin 3_libraries_tongue
Loaded plugin 3_libraries_tongue
Importing plugin 4_rendering_9_viewer
Imported plugin 4_rendering_9_viewer
Loading plugin 4_rendering_9_viewer
Loaded plugin 4_rendering_9_viewer
Importing plugin 4_rendering_opengl
Imported plugin 4_rendering_opengl
Loading plugin 4_rendering_opengl
Loaded plugin 4_rendering_opengl
Importing plugin 4_rendering_scene
Imported plugin 4_rendering_scene
Loading plugin 4_rendering_scene
Setting rendering_width is already declared. Adding it again has no effect.
Setting rendering_height is already declared. Adding it again has no effect.
Loaded plugin 4_rendering_scene
Importing plugin 5_settings_0_settings
Imported plugin 5_settings_0_settings
Loading plugin 5_settings_0_settings
Theme makehuman version 1.2.0
Loaded plugin 5_settings_0_settings
Importing plugin 5_settings_mouse
Imported plugin 5_settings_mouse
Loading plugin 5_settings_mouse
Loaded plugin 5_settings_mouse
Importing plugin 5_settings_shortcuts
Imported plugin 5_settings_shortcuts
Loading plugin 5_settings_shortcuts
Loaded plugin 5_settings_shortcuts
Importing plugin 5_settings_userplugins
Imported plugin 5_settings_userplugins
Loading plugin 5_settings_userplugins
Loaded plugin 5_settings_userplugins
Importing plugin 6_help
Imported plugin 6_help
Loading plugin 6_help
Loaded plugin 6_help
Importing plugin 7_data
Imported plugin 7_data
Loading plugin 7_data
Loaded plugin 7_data
Importing plugin 7_example
Imported plugin 7_example
Loading plugin 7_example
Loaded plugin 7_example
Importing plugin 7_expression_mixer
Imported plugin 7_expression_mixer
Loading plugin 7_expression_mixer
Loaded plugin 7_expression_mixer
Importing plugin 7_logging
Imported plugin 7_logging
Loading plugin 7_logging
Loaded plugin 7_logging
Importing plugin 7_material_editor
Imported plugin 7_material_editor
Loading plugin 7_material_editor
Loaded plugin 7_material_editor
Importing plugin 7_profile
Imported plugin 7_profile
Loading plugin 7_profile
Loaded plugin 7_profile
Importing plugin 7_save_targets
Imported plugin 7_save_targets
Loading plugin 7_save_targets
Loaded plugin 7_save_targets
Importing plugin 7_scene_editor
Imported plugin 7_scene_editor
Loading plugin 7_scene_editor
Loaded plugin 7_scene_editor
Importing plugin 7_scripting
Imported plugin 7_scripting
Loading plugin 7_scripting
Loaded plugin 7_scripting
Importing plugin 7_shell
Imported plugin 7_shell
Loading plugin 7_shell
Loaded plugin 7_shell
Importing plugin 7_targets
Imported plugin 7_targets
Loading plugin 7_targets
Loaded plugin 7_targets
Importing plugin 8_asset_downloader
Imported plugin 8_asset_downloader
Loading plugin 8_asset_downloader
module.load(self)
Importing plugin 8_server_socket
Imported plugin 8_server_socket
Loading plugin 8_server_socket
Loaded plugin 8_server_socket
Importing plugin 9_export_bvh
Imported plugin 9_export_bvh
Loading plugin 9_export_bvh
Loaded plugin 9_export_bvh
Importing plugin 9_export_collada
Imported plugin 9_export_collada
Loading plugin 9_export_collada
Loaded plugin 9_export_collada
Importing plugin 9_export_fbx
Imported plugin 9_export_fbx
Loading plugin 9_export_fbx
Loaded plugin 9_export_fbx
Importing plugin 9_export_light
Imported plugin 9_export_light
Loading plugin 9_export_light
Loaded plugin 9_export_light
Importing plugin 9_export_mhx2
Imported plugin 9_export_mhx2
Loading plugin 9_export_mhx2
Loaded plugin 9_export_mhx2
Importing plugin 9_export_obj
Imported plugin 9_export_obj
Loading plugin 9_export_obj
Loaded plugin 9_export_obj
Importing plugin 9_export_ogre
Imported plugin 9_export_ogre
Loading plugin 9_export_ogre
Loaded plugin 9_export_ogre
Importing plugin 9_export_stl
Imported plugin 9_export_stl
Loading plugin 9_export_stl
Loaded plugin 9_export_stl
Importing plugin 9_export_uvmap
Imported plugin 9_export_uvmap
Loading plugin 9_export_uvmap
Loaded plugin 9_export_uvmap
Importing plugin 9_massproduce
Imported plugin 9_massproduce
Loading plugin 9_massproduce
Loaded plugin 9_massproduce
Loading GUI
Loading theme
Applying targets
Loading macro targets
here it is If it helps the alpha version works fine on my old slow computer
williamb
