More Vertex Problems?
Postby skribe » Fri Jun 19, 2020 2:33 pm
Hi:
Any clue what's causing this and/or how to fix it?
Here's how it looks in Blender before its sent to MH:
I've tried a couple of methods to create the sleeves:
1. Sculpting.
2. Cutting them off near the shoulder and extruding.
Both end up with similar bugs/problems.
Cheers,
skribe
skribe
Re: More Vertex Problems?
Postby joepal » Fri Jun 19, 2020 5:56 pm
In general, the further away from the body a vertex is, the less precise the result.
This said, did you match vertices to the helper geometry? That should yield somewhat better results, although you shouldnt expect miracles.
Postby skribe » Sat Jun 20, 2020 1:07 am
joepal wrote:In general, the further away from the body a vertex is, the less precise the result.
Thanks for the reply.
No I didn't. Can you point me toward a tutorial/docs showing the process?
Cheers!
skribe
skribe
Postby MTKnife » Sat Jun 20, 2020 6:14 am
MTKnife
Postby skribe » Wed Jun 24, 2020 12:10 pm
MTKnife wrote:http://www.makehumancommunity.org/wiki/Documentation:Clothes#What_if_automatic_vertex_groups_don.27t_work.3F
Thank you
skribe
